Steering wheel Boot
(In Topic #223770)
Is anyone aware if its a mot failure if you have no steering rack boot ' Its a 88 auto 1.8
Does any one have a spare ??
Last edit: by okmate
In the end the steering rack needed replacing, it was the original rack so 25 years and 250,000 miles of use it was due and that's when I fitted a new rubber boot.
Wrap the new boot in something like a plumbers solder matt and it will stop it cracking with the heat from the exhaust down pipe.
I used this type with a couple of cable ties to hold it in place.
https://www.ebay.co.uk/itm/Soldering-Mat-Heat-Proof-Resistant-Plumbers-Brazing-Pad-300-x-250mm-10-x-12in/112900616177?epid=21011533748&hash=item1a4966aff1:g:hjEAAOSwjexbn8oG
https://www.ebay.co.uk/itm/Mk1-Golf-GTI-Tintop-Cabriolet-Steering-Rack-Rubber-Boot/254473572058?hash=item3b3fce8eda:g:gXcAAOSwVGFZrUmU
Or here.
https://www.classic-vw.co.uk/mk1-golf-steering-rack-knuckle-boot-172419523-jetta-scirocco-caddy-19141-p.asp
They have gone up in price since I replaced mine… I thought £30 was a lot of money for a rubber boot !!
2 new spares…
1 old with silicon repair
What with collection i have to keep spares.
On the drive
Myvalver 89 GTi Grey mk2 16v
Is it best to go from under the car or can these be replaced from above?
I have seen horror stories about repairing them…
I must say it was a right old job.
Firstly I undone the UJ in the engine bay i took the bolt out so the UV could fall once I undone the UV from inside the car.
Undone the UV in the car and gave it a gentle tap it came off rather easy.
I only realized that this method worked when I was trying to put back together.
Good job done' the car is also a quieter now
Current rides:
I'm looking for OEM spec filler neck to tank hose, someone is having probs getting a 1.1 exhaust.
Might be time to fast forward and restart with an early BMW Mini….
https://www.werk34.de/en/rubber-for-universal-joint-fits-for-golf-mk1-419.171.523.html
In stock at Germany.
