Rocker cover gasket
(In Topic #206862)
![a9wyn in the usergroup ‘Local’ a9wyn in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I am going to replace the cork rocker cover gasket on my '83 GTI Cab.with another cork one. The question is , do I use silicon sealant as well on the gasket or fit it dry.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1552036688.jpg)
![Backinblack in the usergroup ‘Old timer’ Backinblack in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Personally i don't believe in silly gum😄 Just a smear of grease to help it seal on the cover and head. That said if the faces are a bit mangled then you might have no choice.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/notb1.jpg)
![zorg in the usergroup ‘Old timer’ zorg in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I've replaced several on mine and the times I used sealant they have wept.
i pressed the little red button
![Avatar](https://i1236.photobucket.com/albums/ff460/daniel060979/2012-07-2610075.jpg)
![Daniel060979 in the usergroup ‘Old timer’ Daniel060979 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Personally I would upgrade it to the rubber seal.
![golfcabrio in the usergroup ‘Moderators’ golfcabrio in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![golfcabrio in the usergroup ‘Local hero’ golfcabrio in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
There's very mixed opinions on whether to use cork or rubber but for what it's worth I'd go for cork just smeared with a little oil as above.
Just make sure that both surfaces are nice and clean firstly.
Secondly do use the correct torque settings and don't try to guess!
![001.JPG 001.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1508058319/uploads/attachments/59e324cda030d.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Adj%20Jan%2018%20.jpg)
![Deandubya in the usergroup ‘Paid Member’ Deandubya in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Deandubya in the usergroup ‘Local hero’ Deandubya in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
personally gone for a rubber gasket for longevity too… did it in the past few Months
