labour instruction tkt / build sheet found under carpets
(In Topic #185516)
![G60RGE in the usergroup ‘Old timer’ G60RGE in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
can anybody make any sense of what all the numbers mean?
im basically trying to work out the serial number that would have been printed on the vin tag of my car as it never had one, as i still have this tkt i was wondering if it would be on there as there is a 7 digit number called kenn-nr on it
heres a pic of the tkt
![](https://img.photobucket.com/albums/v397/G6ORGE/D028EBBA-8EBE-4259-BB70-24F140B0DA96_zpsqgrkyxz9.jpg)
thanks
thanks
![jrgibb in the usergroup ‘Local’ jrgibb in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
It's a lunch order from the Wolfsburg factory
Can't see anything there that obviously ties it to the vehicle (vin etc), may be a docket from the assembly line there's often bins of components for assembly at certain points one the line??? Or it could be the carpet manufacturers docket, who knows?
Last edit: by jrgibb
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.type72.com%2Fmygtiavi.jpg)
www.type72.com/gti/
lol somone must know
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Can't help I'm afraid, but do have one lurking in my MK2 behind the centre console
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/zender%20avatar.jpg)
![bacardincoke in the usergroup ‘Old timer’ bacardincoke in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
wow, i appreciate that information mate, i think i may have my serial number then..
could someone confirm this for me by matching the kenn-nr with the serial number printed on their vin tag please?
If I've read it correctly (Google translate!) and assuming his information is right the 'Kenn-nr' means the following'…
'The first two digits indicate the week of production and the third digit the day of the week. The last four digits are the serial number for that production day.
Your slip would therefore refer to a vehicle made on the 5th day of the 10th week and the production number allocated it for that particular day was 0864.
You'd need to know the year of production and what day the beginning of the week was calculated from to work out the exact date of manufacture.
The digits used for the 'Kenn-nr' don't seem to reflect the chassis number unfortunately.
It looks like the other numbers may refer to the equipment fitted at the factory… Here's a literal translation from his site via Google.
The equipment codes
In addition to the standard equipment , the Golf has a factory already , the customer can not individually upgrade their vehicle . Each of these extras has got its own code number. This code number is on page 4 of the letter and on the sticker that sticks in the trunk. Who wants to know when he purchased used golf equipment items which have been ordered by the original owner as extras , must to decipher the equipment codes .
The codes I found in the spare parts catalog of VW. Unfortunately missing a few numbers. Has VW over time have forgotten myself .
Within the nine -year construction of the Golf 1 , the features have changed several times. Some things she gave away only at the end than at the beginning of the construction period , and others. If an extra is not occupied by an equipment code , the extra is attached either in series or later .
The prefixed letter "M " and "S " stand for more facilities and special equipment and are not indicated in the codes in the car.
M010 side panel and mesh wall ( Golf Post )
Padded steering wheel M018
M020 Speedometer in miles ( export)
M022 Sealed Beam headlamps (Export)
M025 Speedometer with kilometer count
M026 Activated charcoal to absorb the fuel gases (Export)
Lockable fuel cap M032
M034 dashboard lights not fully switched off , indicator light, front clear and side repeaters , without warning lights ( export)
M034 rear coil springs reinforced (Export Italy)
M037 Without warning lights ( export)
M038 Without front passenger seat
M039 rear seat cover in place
M044 two-point belt Front and knee pads
M046 flashing lights laterally (Export)
M048 door trim , armrest , ash back and reclining seat (Police)
M049 brake pad wear indicator
M050 Dual-circuit and hand brake control people
M059 washer with electric pump
M062 sun visor without make -up mirrors and modified silencer (Export)
M062 4-cylinder petrol engine with exhaust gas cleaning system (Export)
M067 Battery 12V 54Ah Enhanced
M074 Strainer
M078 leatherette covers instead of upholstery fabric
M080 front disc brake
M082 aid kit holder
M083 warning triangle bracket
M086 self -adjusting rear drum brakes (Export)
M089 windshield laminated glass
M100 multi-function display
M102 Rear window defroster
M103 Reinforced shock absorbers
M104 adjustable instrument lighting
M105 Keihin carburetor (Export)
M106 upholstery , special type material (post- golf)
M123 special long-distance interference ( export)
M124 Headlight Bulbs Yellow light (Export)
M130 waist belt for rear seats
M138 Rubber floor covering and additional panels ( Golf Post , police)
M148 rear seat and backrest folded down
M149 Lacquered instead chrome parts
M155 wheel trim chrome plated disc wheel for
M156 air filter for dust- rich countries (Diesel)
M157 4-cylinder petrol engine with exhaust gas cleaning system (Export)
M160 Starktonhornanlage
M164 steel rim 5Jx13
M162 rubber strips for bumpers
M168 Calibrated Angleichgetriebe for tachograph and odometer
M179 upholstery , special type material (Police)
M183 waist belt for rear center seat
M184 three-point seat belt for front seats
M186 waist belt for rear seat up 17-9-3361000
M186 three-point seat belt , rear left and right 17-9-3361001
M187 headlights left-hand traffic
M188 for vehicle use in warm countries
M193 compliance with emissions regulations and Electrical Equipment (Export)
M206 rear view mirror dimming
M208 trailer operation
M222 4- cylinder diesel engine
M224 Kofferraumabdeckung
M227 Increased front seat back
M228 upholstered panel
M229 rear head restraints ( Jetta )
M230 stretch ceiling closable over the front and rear seats
M238 Running Light (Export)
M240 motor with hollow piston for fuel with lower octane
M245 rear window is not heated
M249 3 -speed automatic transmission
M255 shift and consumption indicator
M258 headrest adjustable front
M261 outside mirror passenger side (plan)
M264 urban delivery
M265 Without rear seat and backrest , with cover for luggage compartment floor and hardboard side panel (Export)
M268 rack under the seat
M276 construction with additional reinforcements
M277 4-cylinder petrol engine 52HP (Export)
M283 brake controller
M288 headlight washer system
M303 engine underbody protection
M308 gas spring instead of folding prop
M309 Disc Wheel 4,5 x13, handle and bumper profile for rear bumper (post- golf)
M330 exhaust pipe middle
M335 4-cylinder petrol engine 70HP
M340 Seat heating
M355 4- cylinder turbo diesel engine
M358 EGR valve in a modified installation position ( export)
M376 4-cylinder petrol engine with exhaust gas cleaning system (MKB GS) (Export)
M376 4-cylinder injection engine with exhaust gas cleaning system (MKB JJ ) (Export)
M408 Disc Wheel Steel 5.5 x13
M409 front sports seats
M415 Disc Wheel Alu 5x13ET45
M416 safety steering wheel
M423 storage for audio cassettes
M425 rear wiper
M451 Disc Wheel Alu 5.5 x13ET38
M471 Sport version
M471 Sport version with black trim
M477 Disc Wheel Alu 5.5 x13ET38 ( Jetta )
M480 210mm clutch
M481 5-speed gearbox (4 + E)
M482 Disc Wheel Alu 5.5 x13ET38
M485 Disc Wheel Aluminum 5x13 ET45 or 5.5 x13ET38
M506 brake booster
M522 net partition
M527 outside mirror passenger side ( convex) adjustable from the inside
M528 outside mirror passenger side ( convex)
M541 5-speed manual
M549 three-point seat belt front
M551 headlights with halogen bulbs ( H4)
M555 4 -speed manual transmission
M556 K -Jetronic fuel injection system (Export)
M559 preparation for the subsequent installation of an air conditioner
M560 steel sunroof
M561 hung windows
M565 Sport steering wheel
M568 green heat -insulating glass
M571 rear fog lamp
M572 double horn
M573 Air Conditioning
M574 Disc Wheel Steel 5x13
M589 4-cylinder injection engine 110/112PS
M591 storage compartment under the dash panel on the passenger
M598 4-cylinder petrol engine 60hp
M599 4-cylinder petrol engine 85PS
M600 4-cylinder petrol engine 70/75PS
M602 Luxury amenities GL / GTI
M603 Luxury amenities CL
Australia M608 version ( export)
M613 12V installation Nahentstört
M616 reversing lights in fog light
M618 light machine 55A
M619 light machine 65A
M633 electrical system with Nahentstörung
M642 intake air preheater (Diesel)
M643 tray for front doors
M650 convertible top frame with hydraulic actuation
M652 wash-wipe interval relay
M657 Power Steering
M659 fog lights
M666 elimination of paint preservation
All leaded M673 drive shaft for speedometer
M675 Tachometer
M921 odometer
M929 cover for wheel opening front and rear ( Jetta )
M931 adjustable mirrors (plan) passenger side from the inside
M981 Leather interior
S704 Power Steering
S705 Gußnockenwelle
S707 Special Action "Golf GTI " from 17- D- 448 319 1
S708 Special Action "Rabbit 82 " (Export Austria )
S711 4-cylinder petrol engine 75/85PS (export, Scirocco )
S712 Special Action "Golf GTI 4-door " from 17- C- 470001-999999
S712 Special Action "Golf GTI " with bumpers, fender flares and rear-view mirrors in body color from 17- D- 448 319 1
S715 Special Action " Jetta SL "
S720 injection pump
S722 Special Action "Golf SC" from 17- B- 100001
S724 Special Action " 3 million golf anniversary" from 17-9-3361001 to 3750000
S725 Special Action "Golf GTD " from 17- C- 550001
S726 Special Action "Golf LX " from 17- D- 450001
S726 Special Action " Jetta LX " from 16-E - 010001
S727 Special Action "Golf GX " from 17- D- 450001
S730 Special Action " Jetta TX " from 16-E - 010001
S732 nameplates for domestic vehicles , model year 1983
S733 gearbox for vehicles with Oettingermotor
S734 Special Action " Jetta CL" from 16- D- 448 319
S734 Special Action "Golf Cabrio" in white from 15 -D - 012001
S738 continued construction of the 82 kW engine with K- Jetronic after July 1983
S739 exhaust system ( export)
S741 carburetor 036129015M instead of 036129017A (MKB GF)
S741 carburetor 036129015R instead of 036129017B (MKB GG)
S742 Special Action "Golf M" from 17-9-3120001 17-9-3750000 up
S745 Special Action "Golf MX " from 17-9-3120001 17-9-3750000 up
S747 Special Action "Golf" from 17-9-3120001 17-9-3750000 up ( export)
S750 aluminum disc wheel 6x14 ( Pirelli rim ) 2
S751 Special Action "Golf" to 17-9-3750000 (Export)
S751 aluminum disc wheel 5,5 x13
S752 aluminum disc wheel 6x14 (Export)
S755 Special Action "Rabbit GTI " from 17- D- 750001
S756 Special Action "Golf LX " radio " Braunschweig " from 17- D- 600001
S761 Special Action "Golf GTI " - Discontinued Series
S787 Promotions center console
The equipment codes
M074 Strainer
M082 aid kit holder
M264 urban delivery
M340 Seat heating
M425 rear wiper
M471 Sport version
M480 210mm clutch
M506 brake booster
M522 net partition
M541 5-speed manual
M560 steel sunroof
M561 hung windows
M571 rear fog lamp
M572 double horn
M657 Power Steering
M659 fog lights
M675 Tachometer
M921 odometer
S704 Power Steering
S705 Gußnockenwelle
S720 injection pump
Do you have either the boot sticker or the plate attached to one of the two uprights on the slam panel positioned front centre of the radiator, behind the grille? The number you're after is on both.
The 'Kenn-nr.' on your slip seems to match the format of the serial number on both of the above even it is written without the gaps on the VIN plate itself.
It sounds like most vehicles would have had that slip tucked up behind the glove box but unfortunately if mines still there I've no way of getting to it at the moment to double check for you.
![](https://i1017.photobucket.com/albums/af298/A91AUX/kennnr.jpg)
![](https://i1017.photobucket.com/albums/af298/A91AUX/kennnr1.jpg)
thanks alot i really appreciate all of this, where do i start,
the car has had front and rear panels replaced
the boot sticker, i made the body shop cut this out of the metal so they dont damage the sticker but by the time i went to collect it they lost it
cf_emoticons__BangHead:
cf_emoti
cons__BangHead:they showed me the rear panel with a hole in it, great, thanks
the front panel had been replaced once before i got the car also so doubt it would have been there
this piece of paper i decided to save that i found years ago could be the only way to obtain the information
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
Last edit: by G60RGE
Oh that sucks they lost the sticker, esp. after cutting it out for you!
useless, the rubbish had been collected otherwise i would have gone through it lol
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/VW_golf1_small.png)
![Shughy in the usergroup ‘Moderators’ Shughy in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Shughy in the usergroup ‘Paid Member’ Shughy in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Shughy in the usergroup ‘Regional Hosts’ Shughy in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Shughy in the usergroup ‘Local hero’ Shughy in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Just seeing this thread now…
Looks like bacardi is right…
I knew I posted about it some time before
Have a look here…
http://www.golfgtisportline.com/index.php/2012/03/my-sportlines-build-date/
Serial number matches up to my build date. VW should be able to confirm that for you if you requested the birth certificate.
![:P](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cheeky.png)
yup, the production date according to vw is 14 march 1983,
reeeesult!
also the german abbreviation for lfd-nr is serial number, so i presume the code number under the vw badge on the vin tag will be 1731
Thats my vin sorted!
thanks all for your help.
next thing to work out is the two codes on the same line next to the serial number on the boot sticker as im going to get one of these made too
problem now is do i put the original engine number on the vin tag or do i put the engine number for the g60 engine that currently sits in the bay
reeeesult!
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
