Timing a 1.8gti
(In Topic #211754)
Pictures, the timing marks can differ depending in year. I had removed my cogs and painted them and painted some white paint on the marks to make it easier to see when changing the cam belt
Crank at 0tdc on the timing finger on the transmission bellhousing under green nut and plug.
Dizzy rotor in the middle of the hash mark stamped on the dizzy side frame….
Aligning the pulleys is ok, if you know where the Dizzy was prior, otherwise you are guessing.
www.cabby-info.com has a pictorial on how it all lines up.
