Suspension advice if poss
(In Topic #223660)
Coilovers or uprated shocks
I am after some advice if poss, I have mk1 convertible that I purchased last summer it came with a set of H&R coilovers on it. It does sit very low and is a very hard ride. There doesn't seem to be enough adjustment to raise it to the height I would like 30-40mm from standard, I was thinking about getting some longer springs to change the ride height. I am now wondering if I would be better getting a new lowered kit (not coilovers) so would not be quite so bumpy poss spax or another not too expensive.
thanks guys
On the drive
Myvalver 89 GTi Grey mk2 16v
Do they adjusters on them for stiffness within the shocks at all? A little knob either at the bottom of the shock or on the top where they stick through the body.
Any pics or product numbers?
Ian
Bilstien B4 - reasonably priced and well respected.
Koni Sport - a bit more expensive, but adjustable damping (what I am going for).
Bilstien B8 - A little more. Some find them a little stiff, but they are meant to be very good.
There are plenty of other options, but those come up a lot.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Whip
/wip/
Noun - Car
/wip/
Noun - Car
the_whip said
You can find them as a kit if you go for the springs as well.
must admit have been looking as a kit but can't seem to find
The fronts in the pics are insert dampers, but the pic are often wrong though. Can always call to check.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
the_whip said
https://www.ebay.co.uk/itm/233057941786
thanks for that I did speak to them they don't have the front struts in uk but can get them in a week so think may go with them thanks, whole kit £400 not bad.
Thanks for your help will give me something to do with all that going on
Cheers Gaz
We could do a deal?
Cheers Gaz
I will give you a shout, I have just got the new Bilsteins and springs. Prob will wait till out and about before doing anything but will drop you a text
If you are interested I have just listed the coilovers on ebay
item number 133401624965
or the link below may work
Rob
https://www.ebay.co.uk/itm/Vw-Golf-Gti-Mk1-Convertible-H-R-Coilovers/133401624965?hash=item1f0f5b4185:g:UeoAAOSwNZNerzpA
Thanks for that I'll keep and eye on them
