Erm whats this bit????
(In Topic #218622)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Hs05-1.jpg)
![1985 in the usergroup ‘Paid Member’ 1985 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![1985 in the usergroup ‘Old timer’ 1985 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Noticed a bit of hissing in the engine bay earlier, turned out to be these 2 vacuum pipes and the joints had split.
Cut them down and pushed them back on but what are they for?
Haynes manual is pretty useless sometimes
![20180817_122050.jpg 20180817_122050.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1534547002/uploads/attachments/5b775438a7afc.jpg)
Current rides:
![IMG_20190803_123357.jpg IMG_20190803_123357.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1567341659/uploads/attachments/5d6bbc56973d7.jpg)
www.cabby-info.com HVAC or Engine Vacuum diagrams.
One is usually plugged off, the other goes to the vacuum reserve through a check valve and a T line to power a/c servos.
If both were leaking it causes your engine to run funnily, and your brakes don't work as well as that is the main vacuum line to your booster.
Last edit: by Briano1234
I followed one to a t-piece at the front of the engine where it had completely come off.
Hopefully I've cured my high idle
Current rides:
