CIS injector puller
(In Topic #223778)
![concunningham in the usergroup ‘Local’ concunningham in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Part needed
does anyone have a CIS injector puller even a home made job.
I cannot seem to get one anywhere except the States and that will take a month.
thanks if you can help.
Con
I will say from what I have heard that you still need a block of wood over the valve cover as you pry so you don't ding that with a pry bend.
If I had one I would measure it and you could probably make your own easily enough….Sadly I have only digifants…
CIS Injector Cleaning, Seal and Holder Replacement
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2avatar2.jpg)
![paceman in the usergroup ‘Paid Member’ paceman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![paceman in the usergroup ‘Old timer’ paceman in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I definitiely remember it being a real PITA and a few scraped knuckles.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/received_10212253851841257.jpeg)
![Kenneth Cartwright in the usergroup ‘Paid Member’ Kenneth Cartwright in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Kenneth Cartwright in the usergroup ‘Local hero’ Kenneth Cartwright in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
where you located come and play at mine, ive got new seals here and the lever plus if not my car im happy to pull until breaks.. oh and ive got new injection hoses to.
ng22 0tu dunham on trent
On the drive
Myvalver 89 GTi Grey mk2 16v
Kenneth Cartwright said
i used a metal trim lever, took rocker cover off, spray with wd40 and 3:1 oil, let soak, warm engine up and spray again then lever and pull, i did this for 12 injectors on 3 cars in 1 day, don't for get there's 2 thread m10 and m12 depending on what injectors installed.
But what about the social distancing…Oh the humanity…
LOL
Haha briano I now work in a garage I'm able to stay open and serve joe public.. but I'm more than happy to loan tools and let guy have a tug…😂Briano1234 said
LOL
On the drive
The Ultimate Face Mask
![Screen Shot 2020-04-16 at 9.23.47 AM.png Screen Shot 2020-04-16 at 9.23.47 AM.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1587043464/uploads/attachments/5e985c86c849a.png)
concunningham said
Thanks. I used a pry bar and widened the gap to fit understand nut on top of injector. Still took a huge force. Bot new bosch injector but the did not come with O ring.bloody scandal!
They usually don't so you have to buy either a set, or individual….
The digifants o-rings are cheap about I think 2 bucks over here for a set of 8.
I know when I would go to the parts store to get an individual set, it was like 5-7 bucks and included all the stuff for a CIS set…..so that is 5X4 or 7X4…. as compared to 2 bucks…
Erm if had cap should have both grey/,black on the internal cap side. And green one on the outside nearest the hose.
If you removed injectors with caps on, and it was running ok, then I would have thought put similar back in. As the ceramic seat thingy is in there.
Any how either way the green o ring from link I sent previous goes nearest to hose. The orings are available most places I shared ebay 1 as it's where I get mine from.
On the drive
![collar.png collar.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1587213505/uploads/attachments/5e9af4c070e07.png)
Do you know the part number or do you have any?
If so same a price
ta
Mine all have shroud collar, that's 4 dx 1 jh and 1kr,this is why asked , was it running before on old injectors that was in as you could unintentionally make an issue of you change to shroud or non shrouded.
https://www.ebay.co.uk/itm/221233249484
On the drive
The car was running until recently when it kept revving real high then dying. It had been lying outside at painters in the rain and got soaked through (cabrio). Since then it ran terribly. The engine was not getting fuel. I done some test and replaced relay but no fix. I decided to replaced fuel system parts as never been done before and the car is an 85. I have new in tank lift pump, main fuel pump, injectors, clean lines.
I also had a small engine bay fire removing old filter. I got a spark when the wrench touched battery terminal despite being disconnected. I installed a new box/fuel meter/filter/ leads just want to seat the injectors properly and get running again. Even though cant go anywhere. Luckily wiring is OK.
Should I replace the injector seats as well? Afraid to drop any krap into engine.
On the drive
