Breaking most parts
(In Topic #157463)
![SexualCastles in the usergroup ‘Local’ SexualCastles in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Here goes a few bits (Am open to sensible offers):
Berg cup front splitter unused £80
Cooling-Mist Varicool meth injection system £200
G60 RSR Outlet £90
VW Motorsport badgeless grill £150
Chrome flag mirrors gaskets and bolts £140
Porsche logo Recaro sports seats and custom Mk1 Brackets with rear seats and bench frame to adapt to fit £240
Ivolante VW Motorsport steering wheel ££180
VW Motorsport Alloy Gear knob £30
Digifiz, all wiring and speedo sender £400
SWG Twin induction kit £100
All prices are open for negotiation
![oldskool_89 in the usergroup ‘Local’ oldskool_89 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
May be interested in the seats if rear bench isnt too much work…
![](https://i625.photobucket.com/albums/tt337/Rapid675/b2c4972e.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1306869/0dad9691.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1306869/ef0df444.jpg)
Heres the rear seats mocked up in the back of the golf and some photos of the original base, I was going to make up a box section from MDF to mirror that of the porsche's centre raised bit for the middle of the seats and mount it all the the original seat bench. Then make a blank section at the front and over it in the same material as my carpets:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1306869/7623c86a.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1306869/c4868071.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1306869/a371ca21.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1306869/4b94a8d2.jpg)
Front seats fitted on custom sub frames:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1306869/e63f0961.jpg)
The seats would come with a couple of sheets of MDF and an original mk1 Golf rear bench frame, if you have welding skills and went to a scrappy you may even be able to straight cut that rear section out of a porsche and weld it into the Golf but a bit more work that way. View from behind the car with the seats fitted:
![](https://vwgolfmk1.org.uk/uploads/pbextract/1306869/cff9e3fc.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1505563524.jpg)
![adi3390 in the usergroup ‘Local’ adi3390 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
Last edit: by adi3390
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
![Avatar](https://i95.photobucket.com/albums/l155/andysmith1980/MK1%20Golf%20GTI/rsz_golfmk11.jpg)
![smudger in the usergroup ‘Local hero’ smudger in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![9double9 in the usergroup ‘Paid Member’ 9double9 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![9double9 in the usergroup ‘Local’ 9double9 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Sticker Pig
SexualCastles said
No GTi cluster im afraid, just the Digifiz
Is the digifiz ready to plug and play or does it need work mate?
Also have a digifiz info booklet printed out and some spare bulbs I can throw in
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/securedownload-2.jpeg)
![twstrong in the usergroup ‘Local’ twstrong in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
SexualCastles said
Are you running a CE2 fusebox with your 20vt? If so yes the Digifiz is pretty much plug and play if the wiring is similar to a corrado, I have all the diagrams to wire in the extra couple of bits (fog light switch etc.) I used two L brackets and cable ties to fix mine in place in the correct position which worked perfectly and I can provide advice through the fitment and wiring.
Did they not come with a mounting bracket mate or am I wrong again
SexualCastles said
The original Digifiz came with brackets but for the later mk2, in order to fit them to a mk1 you have to trim down the original brackets and use the L brackets attached to the top of the dash
Ah sorry mate for daft questions. Is it one of the 8k rev ones or the other one?
It is indeed, will post up some pics when I get home
Cool thanks mate
![collo16v in the usergroup ‘Old timer’ collo16v in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
