Rotten fuel tank - help please!
(In Topic #76132)
![jordster in the usergroup ‘Local’ jordster in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.photodump.com%2Fdirect%2Fjordster%2Frust.jpg)
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.photodump.com%2Fdirect%2Fjordster%2Frust2.jpg)
Thanks for your help
Jord
MK1 GTI Cabrio
Ford Mondeo (Daily drive)
Nissan 350z GT Coupe (the toy)
![Ross in the usergroup ‘Old timer’ Ross in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
It would be better to cut out all the rust and then weld a new section in than to fill it. It all depends on how long you want to keep the car as a repair with filler and mesh won't last as long and you don't want to end up doing it all again. You'll need to cut it out whatever method you chose. Time to buy an angle grinder if you havent got one already!
Crazyquiff is breaking some cabrios so he may be willing to cut out the section you need.
As for the tank… how bad is the rust you see inside the fuel cap? Rust is extremely common here but its just the filler neck that will probably have gone which is separate to the tank. If there are holes then rust and road debris and water will have found its way into the tank so you will probably have to remove the tank to clean it all out properly. If its just surface rust then you may have just caught it in time (obviously don't poke it now as bits will fall in the tank!). Remove the neck when the fuel guage is on red. Cabrio necks are slightly different to hatchbacks and cost more. I've heard you can mod the hatch one to fit cabrios. have a search of the forum!
Good luck matey and keep us updated :wink:
Cheers,
Ross
![](https://i2.photobucket.com/albums/y29/rossonline/sig1.jpg)
![Avatar](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.golfmk1.co.uk%2Fimages%2FExLink%2FAvatar.jpg)
![crazyquiff in the usergroup ‘Paid Member’ crazyquiff in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![crazyquiff in the usergroup ‘Paid Advertisers’ crazyquiff in the usergroup ‘Paid Advertisers’](https://vwgolfmk1.org.uk/themes/default/images_custom/PaidAdvertiserIcon.png)
![crazyquiff in the usergroup ‘Local hero’ crazyquiff in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
