big front seat belt problem
(In Topic #85973)
Rob
Hairyarse said
Only thing I can think of off top of my head is if they are handed and you get left and right mixed up - would make inertia real upside down? :dontknow: and therefore wouldn't work?
nah i keep the 2 belts on the side i took them off, it is like the reels have done up so much that a safety catch inside or something
Topoftherange said
quite simply it sounds like the inertia part has activated and wont release unless you just leave them, inertia belts often do this even when bolted in a car! you be best to bolt the top in and leave it hanging untill you can un reel the rest, sometimes you can fiddle with them and they unravel but the more movement the tighter the inertia part seems to grip!
shall i prop them up with something or let them hang?
paul_c said
Try tilting them at a slight angle rather than exactly vertical.
any angle, or tilt them towards the inside of the car or to the left?
From what I can work out this is not part of the inertia mechanism as with it removed the belt still locked up when pulled quickly and it only activated when the belt is tilted from side to side a lot. May be an extra mechanism in event of a roll over or just to stop belts being re-used?
1983 1100 C
1983 1100 C
markwon said
From memory you need to tilt from side to side (left to right). I've had a couple of locked up belts apart in the past. There's a little ball bearing inside that sits in little cradle with a lever, if the seatbelt is at the wrong angle the ball bearing knocks the lever to lock the belt.
cheers for that i will try that today and let u no how i get on
cheers for the help people
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
dannyboyblue said
Pesky women's touch. You spend hours trying to remove/install/fix something and somehow they can do it in seconds even though they may not have the slightest clue about the car.
tell me about it, "women logic" lol
cheers 4 the help people
