Attaching door drop glass to winder channel securely
(In Topic #139134)
![alancaddy in the usergroup ‘Regular’ alancaddy in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
So I am finding that when I come to wind the window back down, the metal channel/rubber seal is just pulled clean off the glass and the window stays where it is. I have tried using vice clamps to squeeze the channel tightly on to the glass but it hasn't worked
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
Anyone got any advice?
Thanks.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/stanceworks_by_zoptekracing-d4tmb2e.jpg)
![lewis_86 in the usergroup ‘Local’ lewis_86 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
mk1 golf 1.8 8v = sold
mk2 golf gti = burned out
mk3 VR6 = wrote off
mk2 seat ibiza gti = sold
mk5 jetta tfsi = stanced and slammed![;)](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/wink.png)
Mk1 golf = garages and butt naked
mk3 VR6 = wrote off
Squeeze the channel together using pliers etc, but so you can just about get the glass and rubber in
Soak the channel in car wash shampoo (not corrosive, unlike washing up liquid)
Get a tub of hot water and put the rubber in it, to make it pliable
Fit it all together
Rinse the excess shampoo off with cold water
It's holding enough that the window will go up and down, although the glass can still move about a little in the channel. I don't want to squeeze the clamp down anymore in case i crack the glass… Whether or not it will hold when it gets really cold and the window wants to freeze in place is another thing… maybe cleaning it up and lubricating the guides as described above will be the answer.
it'll probably start to ease up on its own after a while, shame you fitted it in the winter really as being sat outside for a few weeks in the baking heat probably would have bedded em in pretty fastCode
The door is still inside while I wait on a new main seal to arrive from mk1 autohaus, i'll leave next to a radiator for a bit :D
Member 125 - 2005
![mk1jim in the usergroup ‘Paid Member’ mk1jim in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![mk1jim in the usergroup ‘Local hero’ mk1jim in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
