1/4 glass window channel....
(In Topic #76482)
![la6vmk1 in the usergroup ‘Regular’ la6vmk1 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
On my search for mk1 doors (3 door) noticed that some had a short window channels. (Between 1/4 glass and winding glass..)
Both my chanels are long. Is it possible to cut them down a few cm before pop rivet at bottom of door, will winder still work and glass stay in place??
I want to fill pop rivet hole at bottom of door, i think that it promotes rot to lower door. :?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Forumpic.jpg)
![Early-1800 in the usergroup ‘Paid Member’ Early-1800 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Early-1800 in the usergroup ‘Local hero’ Early-1800 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
When I restored my GTI I used some doors from an A-Reg Driver 1300. There where lots of detail difference between original GTI doors and the ones from the Driver, you?d think they were from different cars!
I can?t remember now whether I swapped parts between doors or kept the bits with the doors that they came with. I would prefer the long fixing that goes to the bottom of the door, holds the glass better and makes the door slightly stronger.
:dontknow:
:dontknow:
