what ls the best timing belt kit
Hello guys, as above which timing belt kit would you guys recommend, I seen a few which are dayco, Ina, SKF, all.advice appreciated
I always use Gates  :thumbs:
As above or Dayco or continental
I used Gates, however nowadays these belts are replaced on a calendar basis due to the rubber perishing.
Suggest that you don't buy a new old stock belt that has been on the shelf a long time.
The ina kits are good oe too
bert
Thats not a rod knockin,its a diesel stupid! floppy top and 1 tin top
I see I looks on eurocarparts  and they do DAYCO and ina, where do you guys get the gates from? Do I have to specify to the counter guy that I want a new belt not a old stock
I always use the Conti belts and of course fit a new tensioner, I use the Ina tensioner.
I did buy a cambelt from VW a few years ago and that did had a "born on the" date .
Never had a problem with Conti belts for the years I've been using them on both my cars and I change them every 60,000 miles (Haynes says 40,000 miles which I think is to often)
Euro car parts sells the same stuff as in the links below.
http://www.carparts4less.co.uk/timing-belt
http://www.carparts4less.co.uk/cp4l/c/Volkswagen_Golf+Cabriolet_1.8_1988/p/car-parts/engine-parts/belts-chains-and-tensioners/tensioners-idlers-and-dampers/?328440040&1&5f8088ba28ac3d1698e62fbfcc92d0f60a08a2b8da444dd10f8c44609f3cf85095c5a0afb3df49cb&000091
Thanks guys, is there a better quality between gates and DAYCO ?
skf will be good gear, they make excelent quality bearings. usually i end up with bosch timing belts which are also fine
