oil light
(In Topic #187188)
Does the light come on as soon as you start the engine or after a period of seconds or minutes?
Was it doing it before all the changes???
Q. Have you properly checked the oil level using the dip stick when the engine is cold, warm and hot?
Q. Does the light start flashing when you are cornering or just after?
Q, As asked before, did this happen before the pump, oil and filter were changed?
The oil light came on before the work was done,its comes on less since the work has been done though
It came on after turning of a steep hill, Wales is quite hilly
Member 125 - 2005
Not cold or hot.
Start the engine from cold, let it run normally for 2 or 3 minutes (no more) then check the level twice carefully!
if its a gti this is easy just remove the smaller white sender and put it in the head, put your pressure switch in the spare hole. if not you might have a spare hole with a threaded blank in it, if so as above.
otherwise you'll have to swap the high pressure switch from the filter housing to the head and move its wire to suit, you may or may not receive a light and buzzer over 2k if the pressure is too low, but i imagine at revs it should be ok
Straight forward swap the hardest thing is finding a socket long enough to undo it or use a ring spanner and make sure the new sensor/switch has a new little washer on the threads to seal it.
Then keep the old one as a spare as they usally just start to leak oil when they go.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1998/p/car-parts/engine-parts/fuel-and-engine-management/engine-management-switches/?466440020&1&41fb2ff697beba5332f4955e27085155237567fb&000519
I've never heard about checking the oil when it's warm? Only ever done mine when it's cold and seems to work for the 200,000 miles I've driven in the car since I brought it.
