Hot starting problem .. tried everything !
(In Topic #76395)
First post so be gentle please
Got a hot starting problem on my 1.8 Mk1 GTi, and checked the Cold start valve and warm-up reg (both working fine), wired up a switched feed to power the fuel pump and even unplugged the Auxiliary air valve but still takes 20-30 seconds of turning over before it'll start when the car has been left for 10 or so minutes. The car will always start eventually, and starts first turn of the key when cold but infuriating and embarrassing when hot ..
I've replaced the injectors, fuel pump, accumulator and countless other bits but still not made on any impact on the situation.
I wondered if the replacement accumulator was duff but isn't it unlikely to give exactly the same symptoms as the last one ? Other thought was evapouration in the fuel lines but have run the pump for a five or so seconds before trying ignition and still no difference.
I'm going to swap out the distributor next with a spare one but it seems like a fuel problem to me .. any ideas gratefully received !
have you tried repleacing the Fuel metering/distribution unit?
must get my injectors out and test them
mine has definately got worse because now for the first minute of running it's really lumpy
I don't think it'll be the ignition distributor as it wouldn't run fine
PhillTMK1GTI said
Prowler, would a faulty hall sender also cause erratic running?
…possibly….as it was explained to me by the auto electrician, the hall sender can 'break down' when it's hot, giving bad starting, and bad running if it's really bad…..all I know is that once he replaced the hall sender my GTI started 'on the button' every time, and still does.
I did have a bit of intermittent rough running after, but that was down to a jetting injector, hence my injector test.
I'll have to source one and see if it fixes mine
It'll start fairly easily if it's only been turned off a minute or so but any longer than 5-10 minutes and it takes a good 30 seconds of cranking.
I found the air flap was way below the conical part on the metering head and wondered if that may have affected the amount of fuel that would be drawn in at start-up (especially with the extra pressure from the WUR once it's warmed up) but no difference after bending the spring a bit to make it seat at the bottom of the cone either.
Timing seems fine but it does run on for a second or so if I haven't turned the fuel pump off before the ignition but thats the only thing I can think off that might be wrong on the car.
I'm stumped .. anyone got any other ideas ?
ta again
It looks like an allen key job to get them out, any idea what size please and if they can be got at without pulling the inlet manifold off ?
Thx again
I have no idea how these come out.. do they not just pull out? :dontknow:
