GTI 1.6 Starting for the first time in 10 years!
(In Topic #85042)
i am now the proud owner of a 1.6 GTI, in need of restoration. I may be going home this weekend, which will be my first chance to get a proper look at it. The car had basically been driven into a garage 10 years ago and left there!
B4 i moved it to my garage, i only had time to check if the engine turned over….. and it DID! i want to see if it will run, there isnt any reason why it shouldnt, as there were not any mechanical problems b4 it was left.
Anything obvious i should check with the engine b4 i try to start it with fresh petrol, a new battery, and some wd40? as in the past i have only ever tinkered with carb'd cars.
cheers James
Mk1 Golf GTI 1600 Black (1.8T in the making)
Audi A3 (standard)
Triumph Spitfire 1500
Audi A3 (standard)
good luck! and report back and let us know!
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Plans for the car are as follows:
Totally original, with slightly breathed on engine (four branch manifold elc), and a drop on coilovers.
The car is in need of a full respray, wings, boot lid, and sills. Everything else is rust free. Which is good! lol
i will post back when i try to start her up!
Cheers James
Audi A3 (standard)
Audi A3 (standard)
After turning by hand . Keep plugs out and crank untill oil light goes out to make sure there's oil circulating before start up. With it being dry for so long the bearings in the cams and crank will need lubing.
Also whilst the plugs are in your hands, give em a qucik bright with some wet-n-dry. You will probably want to replace them anyway once shes runnging..
Also, check to see the meter flap is moving ok. it may be stuck after so long.
TT
It runs!
i'm on easter hols now, so i actually have a chance to mess about with it for a couple of weeks.
Any ideas? :dontknow:
Audi A3 (standard)
Audi A3 (standard)
Check state of fuel filler neck. If rusted may have dropped sh1t into the tank. Will need cleaning out, fuel lines blowing clear, new fuel filter, check intake on pump to see if small mesh filter there too.
http://www.vwgolfmk1.o…5&highlight=injector+test
Have a good read of above on how to check your fuel delivery.
Also check spark is strong and constant.
That's something for you to start with anyway.
