Golf MK1 83 Campaign GTI 1800 DX - Stalling and total loss of power - Help!!!
MK1 keeps cutting out and won't run for more than 5 mins
The car refuses to start.
I have screwed the mixture screw all the way round to the left (lean). Does anyone know how many turns approximately I would need to make - to keep the car running?
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=25972
Can you smell petrol?
Timing ok?
loosen the connections to the fuel filter and is there petrol there?
Post up a picture of the engine etc and we may be able to see something wrong???
I've discovered we have good spark. All new dizzy,rotor,arm,cap,spark plugs and leads. So no issues there.
When we removed injector 1 and cranked the engine, and blocked the port the injector barely let out any petrol and just gave a dribble.
I removed and replaced the WUR pipes for a newer set and checked the filter gauge and cleaned with cotton buds - no dirt or grime came out.
Richard aka CQ advised me to remove the return fuel line and placed into a measuring jug and try cranking the engine over for 30 seconds. I should get 750 cl of fuel in the jug.
I have just tried this a few minutes ago and have discovered that no fuel at all is coming through the return pipe.
Why would this happen?
Brand new flexi fuel lines,fuel pump,fuel tank and filler neck are clean/rust free
Brand new GSF 5 bar pump item which came with the new one way valve fitted
Should I disconnect the black feed line and disconnect from the metering head? And put the pipe into a bottle?
I'm just scared of petrol and any sparks, I'll cover/shield the battery with a cardboard box - is that safe?
Did as advised and disconnected the black supply line from the end of the filter (going into the metering head) and placed the pipe in a empty bottle. Disconnected the black wires & tried cranking the engine for 30 seconds.
No fuel came through at all? The GSF pump is made by Vetech & when I turn the ignition i cannot hear the fuel pump buzz at all??
I've just tried turning the ignition with the fuel pump hanging down a bit a check the terminals with a multimeter and appears to getting no reading. Does anyone know where the wires from the fuel pump run across into the fuse box? Is this the same wires that go from the top of the tank for the fuel gauge?
The level sender wires go to a different pins but then loom does run together most of the way
You could bridge the 2 bigger connections on the fuse box where the relay normally lives and that should make your fuel pump run even with the ignition off.
Or take the replay out underneath the fuel pump relay, turn it around and fit where the fuel pump relay lives then the pump should run with the ignition on.
