Fitting A New Head?
(In Topic #83103)
Fitting A New Head?
(i've never really done engine work before like this, i've only ever cleaned carbs / replaced suspension / brakes e.t.c)
i done my a few months ago and had it off done the head work and back on in a day and a half!
If you can't it's still doable, but you will end up with grazed knuckles :x
The head is located onto the block by the head bolts, and by a couple of steel pins - so "fitting" it is a no brainer.
Re-attaching all the ancilliaries (intake/exhaust manifolds) is the thing that can take the time - and is the main reason paying someone else to replace your head gasket costs so much.
Ali Cabrio
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
It is removing/replacing the head that takes the time and is a pain.
Replacing a head gasket is ?40 - parts, ?660 labour approx.
Ali
Seat Covers
Scratches
Leaky roof
Seat Covers
Scratches
Leaky roof
You also will not increase compression ratio, but reduce it (all the bits of muck/rough casting increase the compression ratio). The point is it the compression ratio is returned to what it should be when it was built and therefore how the engine was designed to run. Bear in mind the head is only one half of the engine. If you have dodgy piston rings or weak bottom end bearings they might not take or detract from the increased performance/effiency of the reconditioned head.
Happy porting
1983 1100 C
1983 1100 C
