Engine mount removal problems
(In Topic #192792)
![Mcdubber1 in the usergroup ‘Paid Member’ Mcdubber1 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Mcdubber1 in the usergroup ‘Local’ Mcdubber1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I also unbolted the front mount for extra movement even though I'm retaining the poly bush in it.
I've removed the big bolt in the centre and a bolt from underneath at the rear and there looks to be an Allen bolt on the top but this is fouled by the poly insert. The only way I can think of getting to it is by cutting the insert.
Is there any other bolts that I'm missing and is there another way to go about removing this mount? Dropping the engine right down or lifting it up seems like it would work but I'd rather avoid that if possible.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/th_fff9e3ea.jpg)
![Brad. in the usergroup ‘Old timer’ Brad. in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![:ocf_emoticons__punk:](https://vwgolfmk1.org.uk/themes/default/images_custom/ocf_emoticons__punk.gif)
Cheers for the help mate
