Coughing and Chokeing Engine
(In Topic #131568)
![Avatar](https://i668.photobucket.com/albums/vv50/arikkamm/img02551.jpg)
![Arik in the usergroup ‘Regular’ Arik in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
My Engine is coughing and chokeing in low Idle and whan im in first gear
i dont now if you can see that on the video but I uploaded it to youtube…
here she is:
paul_c said
Too rich mixture. I don't recognise the engine though, possibly a Digifant? Do you know the engine code? Is it on the V5 or equivalent?
its a 1.8 inj 2H…
how do i change the mixture?
p.s.
i have a open air filter…
http://www.golfgtiforum.co.uk/index.php?topic=33253.0
make sure you check the ignition timing first though!
edit: your blue temp sender may be white, either way its the 2 pin one in the flange on the front of the head
fund the problem!!
I had a very small crank in the ink mainfold… you can allmost cant see it.
and in the last month the car start to shake and jumping!!
i check the hood, and faund that the crack become a very big hole…
i took it down and fix it with a inner lining and a glow. and all of my problem has gone…….
its runs. so smoth!
fantastic!1!
thanks you all…
