Cambelt timing marks
(In Topic #204494)
Why do you want to look at the flywheel marks?
I adjust the timing by advancing the timing till it starts to pink under load the back it off a little till it stops pinking but you need to be driving the car and stopping then adjusting so you need a quiet country road for this.
Also the timing depends on what fuel you are using, super unleaded (best fuel to run these cars on) or normal unleaded as the timing needs to be retarded.
Crank at the Diamond on the tranny. (0TDC).
Dimple on the Cam at the top of the valve cover.
Don't use the pulleys…..
Take the Cap off the Dizzy, and the rotor should be in the middle of the Hash mark that is stamped on the side frame of the dizzy housing.
Also, simple question re: running advance… Is that a higher degrees, as in 7degrees is more advance? I never know which way to turn the dizzy to advance or retard the timing?
1992 MK1 Golf GTi Rivage - Classic Blue Metallic - Long term project
1991 MK1 Golf GTi Rivage - Classic Green Pearl - Sold
Anti clockwise = retard.
mark1gls said
Clockwise = advance
SO… That means advances is 7degrees, 8 degrees and so on?
I keep advancing it till it "pinks" under load then retard it till it stops. Job done, no special tools other than a 13mm spanner and a 7mm spanner to adjust the tick over speed.
Only ever had to adjust the timing a few times in the 20 years of having the car, when I tried to run normal unleaded then when I went back to super unleaded and when I changed the engine over to one I had rebuilt so I don't ever mess with it once it's set.
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14915
ignore the setup procedures obviously. for ignition timing you set this up at idle with the vacuum line to the dizzy disconnected and plugged, using the big diamond. for idle and co this is done at idle, with the breather off if the oil is heavily contaminated. aim for about 1.5% co, YMMV
but as above you can usually add more advance with decent fuel, 8 degrees is a good starting point (or just a smidgeon further round than the diamond )
the digi/16v are basic non-advance dizzy without weights or vacuum
