Advice on Flushing coolant.
(In Topic #78415)
Hi all.
After repairing the outlet flange on the side of the engine block i thought now there is not much coolant in there anyway i would flush and replace the coolant.
I have bought some G12 plus coolant which i think it pretty good. :dontknow: .
I need some advice on how to flush the system. I know to remove the top pipe from the radiator and attach a hose pipe to it. Do i then take of the bottom pipe attached to the water pump and flush through until clear.??.
I might sound a bit stupid but it is the first time i have done this. :dontknow:
Thanks for your help.
hi mate,
you have to take the bottom elbow piece off the water pump and remove the thermostat (prob worth checking this whilst its out) and then you can flush the system…
ok bob…
ok bob…
Mk1 golf gti campaign… 16v ish…
MK3 gti 16v
is the mk1 rusty? depends what you mean by rust….
MK3 gti 16v
may thanks bob.
