16v manifold on 8v engine
(In Topic #75908)
![larke79 in the usergroup ‘Regular’ larke79 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
right here's my problem.
I've got a basic 1.1 mk1 golf and i'm having an engine transplant. the new engine is going to be an 8v gti engine running a carb. i want the manifold and exhaust to be standard vw kit at the moment.
so basically thinking of running a standard mk1 gti exhaust and using a 16v manifold as apparently the outlet's are lager, so better performance???
does any one know if this is the case and if it is possible to fit a 16v manifold to an 8v engine in a mk1?? or should i just stick with the 8v manifold!
any would be good
any would be good
![dub-ha8 in the usergroup ‘Local’ dub-ha8 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
A 16v manifold will not fit onto an 8v head without work.
www.vwcaddy.com
