Weber 32/34 DMTL Fuel Starvation/Flat Spot
(In Topic #159800)
Mk1 Clipper with 1.8 Auto engine and box in it and a 32/34 dmtl weber (virtually new)
Car runs and idles perfectly, smells all good so all seems well.
Whenever i try and accelerate between 850 (approx idle) and 2000 rpm i get a massive flat spot which pretty much cuts the engine out.
Seems to me like a fuel starvation problem.
Bypassed the fuel seperator to see if it was that, no difference.
Had the timing checked, its bang on. Dizzy runs a constant advance system as far as i can tell? Works fine and timing marks all line up so cant see it being a timing issue.
All vacuum pipes are connected right, the base plate is near enough new and in good condition and the carb itself is in generally mint condition.
Someone has mentioned about the accelerator pump maybe being an issue? It seems to work pretty much as it should, although there isnt any fuel coming from the jet on the first bit of my acceleration? possible problem or?
There is a tiny slight leak on the exhaust manifold because when i pour water over it the engine dies down a little bit but i dont for one minute think its enough to cause the problems im having?
Ive got pretty good mechanical knowledge and have had no luck whatsoever with this, ive gotta be missing something obvious?
I remember the Pierburg having a similar issue which i think i resolved by adjusting the mixture but im 95% sure the mixture and idle are fine on this at the moment?
HELP Alex
Last edit: by Benchdollar
Timing could be out, is it set via a timing gun? I did the same and my car drove trebble, dogging down when pulling away you had to rev it go to get going.
Run the car and advance the timing (losen clamp and turn the dissy anticlockwise, you might need to change the tick over as well) till the car starts to "pink" under load (30 mph and slowly flooring it in 5th) Will take a few attemps to get it right, start, stop get out turn the dissy again drive a bit, etc.
If you make where the dissy is to start with if it does not work you can always go back to where it was.
Spotted you have a swirl pot fitted..
http://sciroccoregisterforum.co.uk/carforum/viewtopic.php?f=12&t=15397
Really running out of ideas !
Alex
Let us know what happens..
I did find that with the airbox off if i use my hand to cover the top of the carb almost fully then the problem pretty much goes away which indicates to me its deffinitely an air issue somewhere?
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-carb-engines_2%2Fstuttering_2
