Rocker cover studs
Rocker cover studs
:banghead:  :banghead:  :banghead:
Where oh where can i get some new 1s, cant find any
Instagram Firemandan1
seriously!! EBAY you can get Nice shiny ones too with nuts
If you buy the new style rubber gasket it comes with a complete set of conversions studs !!
Cheers,
Ade
yea i bought the 1s from ebay bloke said there for the 1.8 carb and they dont fit, far to short..
rubber gaket ? is there much diff to the cork 1s,
Thanks tho guys
if your using a cork one, then the ones you have should be fine, if your using a rubber gasket its alot thicker so you need to change the studs
you can get the rubber gasket and studs as a pack new from VW, think i paid about £25 though
Think a few on here use a mk2 one
Rich
1.8T CABBY
Some of the aftermarket studs also have a hex allen key hole in them, makes stud extraction easier. But they don't have the retaining collar so ensure you use some loctite and measure things correctly.
R32GUY
1992 Rivage in Classic Blue Pearl "B16YUG" 2.0 TFSI, 6 Speed FWD with Quaife LSD, running on Air with sorted geometry and Eibach ARB's, G60 brake setup front and rear, 4x100 17" BBS LM's, Power Steering, Opening Quarter-lights, Mk2 electric recaros and the whole car trimmed by MJ Interiors in tan and Alcantara with a brown roof.
Yea cheers guys, cant use the old 1s because the old owner must have used a lump hammer to tighten them up, they were f**ked… my get the plastic 1, give it a try
Two nuts locked onto the stud and then use an impact driver to loosen them :-)
Cheers,
Ade
na, all the threads were shot, got them out now just having a ball ach to find proper new 1s
026198025c is the part no. for the rubber gasket for the rocker cover and it was about £16 when i brought it a few months back.
G60
Cheers andy, wheres that from ??
From vw dealers dude.
G60
sound, Thanks for that
you could just use m6 bolts instead :)
Cheers john, got them from the main dealers in the end
Just called VW, this kit is now obsolete. The studs (N 101 863 01 @ 16p each +VAT) are still available to order - which is just as well as most of the aftermarket rubber gaskets don't come with them.
Bluefox
Current: '84 Golf C 1.9 TDI | '83 Golf GX | '01 Polo 1.6 GTI | '01 Audi A2 TDI SE | '83 MG Metro | '06 Daughter!
Previous: Yep.
Also thanks to our own Rubjonny for posting those part numbers on another forum! :)
Bluefox
Previous: Yep.
He's a good lad is Jonny  :thumbs:
