Golf Clipper (1991) 1.8 carburettor won't start
(In Topic #116712)
I have an Mk1 Golf Clipper (1991) 1.8 carburettor Manual. I recently ran out of fuel. I added a can of petrol and the car started after one or two attempts. I drove the car for about half a mile and it lost power and cut out.
I added another can of petrol thinking it was a fuel problem. The car has never started since.
I have tried the following:
? Checked the fuel tank and lines for blockages
? Changed the fuel filter (inline)
? Tested to see if the fuel pump is pumping petrol to the carburettor, which it is.
? Removed carburettor and cleaned the jets.
? Checked the spark plugs are sparking
? Changed the dizzy cap.
? This car has a new ignition coil, battery, leads and plugs.
? The car is trying to turn over.
Does anyone have any ideas?
Chris
General News
Traceycab's new Weber DMTL carb needed quite a few squirts to get it turning over fast enough to prime the fuel lines (I did notice you said the pump was pumping!) …its been no trouble since!
If it doesn't at least fire then maybe your timing has slipped (improbable)
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
also pop out the fuel level sensor, iirc on the carbies the fuel lines run to this, could be the filter on the base of it is clogged up
