Clipper tickover
(In Topic #89746)
![ezzysi in the usergroup ‘Newbie’ ezzysi in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Clipper tickover
Shes ticking over at around 1100rpm wnen fully warmed up so need to wind it down a bit.
Cheers all..
![mk1-1985 in the usergroup ‘Regular’ mk1-1985 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Carb adjustment
![](https://i174.photobucket.com/albums/w96/jgilber2/openbonnet.jpg)
look at left hand side of the carb to the rear the large disc shaped object should have a nut on the back of it that will adjust idle speed. It's a tight squeeze but you can fit your hand behind and adjust with a small wrench/spanner.
![](https://i174.photobucket.com/albums/w96/jgilber2/carb.jpg)
Sorry I cant remember which way increases or decreases hope all this helps
I'd say be very careful as any adjustments can have a knock on effect on the carb.
Jamie
