Bike Carbs on 1.5 JB
(In Topic #86641)
![1mk1dub in the usergroup ‘Newbie’ 1mk1dub in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I have purchased a set of Yamaha XJR1300 carbs to be mated to a custom manifold. I shall be replacing/adding a Facet Red Top fuel pump, and changing all the fuel lines. I am hoping that with a litle bit of tweaking judged by an air/fuel ratio gauge they should be good enough to get me to someone to tune and set them up properly.
Now from what i can see i shall have to change the throttle cable, and the vacuum set up slightly to get it all working as it should.
Is there anything i have missed or am i completely mental in attempting this? I just thought it would make a change to the norm and be something a little more involving rather than forking out ?300 for a new bolt on carb.
I think that if done correctly i should see a bit of an improvement in driving and power perhaps not to mention an amazing sound!!! Will i see a change in rev limitations?
The way i have looked at it is that the carbs are for a 1300 engine that revs to 15/16k and so should be suitable for a 1.5 in most situations, perhaps running a little lean lower down the rev range but should be ok with a re-jet?
Please feel free to tell me what you think of the idea and me, im no where near a complete know-it-all and like learning from others so any advice is welcomed.
Joe
