1.5 solex wont run until butterfly in the top of the carb is open
(In Topic #185567)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Image1587331339917.jpg)
![mk1newbie in the usergroup ‘Old timer’ mk1newbie in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Ive got a 1.5 fitted with a solex carb. The car runs rough and will cut out unless the revs are kept up. Once the butterfly on the top of the carb is open the car runs fine. Does this mean the auto choke is not coming on or does it mean the auto choke is staying on? Either way what can I do to fix it.
Thanks.
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/9image.jpg)
![Massbad69 in the usergroup ‘Local hero’ Massbad69 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Then the thing that fixed it was a new condenser and points on the dizzy. £7 fix :-)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/aaaa.jpg)
![arf333 in the usergroup ‘Regional Hosts’ arf333 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![arf333 in the usergroup ‘Old timer’ arf333 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
rubjonny said
Its a 1b3. Think its different.
arf333 said
Mine is playing up too…. im just gonna give in and invest in a new weber
Would you mind advising me on what weber I need?
