New golf, same problem
(In Topic #117793)
![Gazvenn in the usergroup ‘Old timer’ Gazvenn in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
edit:
sorry kind of in the wrong bit of forum and the problem with the last one was the wiper motor staying on i think and draining power but pretty sure its not that on this un.
can someone run me through a couple alternator checks please, would try searching again but took me ages last time and in a bit of a rush as i've gotta be up at 5 for work.
![Madferret in the usergroup ‘Old timer’ Madferret in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
~Madferret
Mk1 1457cc 5door GX '83
![millfischk69 in the usergroup ‘Paid Member’ millfischk69 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![millfischk69 in the usergroup ‘Old timer’ millfischk69 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
\'83 Lhasa Green GX 1457cc
\'53 Mk4 Golf R32, Deep Pearl Blue
\'00 Kawasaki Ninja J1 ZX6R
\'92 B3 Passat Estate 1.6td (Now breaking) 😭
Member 125 - 2005
![mk1jim in the usergroup ‘Paid Member’ mk1jim in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![mk1jim in the usergroup ‘Local hero’ mk1jim in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
while i have had it the car always drove 100% the only thing i can think of , like i suggested in your pm, was sometimes the fan belt did squeel a little . have you checked the belt ? also check how tight it is . i wouldn't have thought it is anything major , change your belt and re-tension it .
and the ciggie lighter doesnt work which meant no sat nav getting home lol
Member 125 - 2005
![gman83 in the usergroup ‘Regular’ gman83 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
~Madferret
So any reading you get is dependant on what voltage the battery is putting out
Anyway you already know you have a battery draining problem and you'd be suprised what current some radios will draw when off.
How long exactly are you leaving it? The only way to really check it without a load bench is to seperate alternator and battery. Do you have an ammeter to measure the current draw from the battery?
~Madferret
![SEAN1151 in the usergroup ‘Old timer’ SEAN1151 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
Member 125 - 2005
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
![mrpurple in the usergroup ‘Paid Member’ mrpurple in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![mrpurple in the usergroup ‘Local’ mrpurple in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
![golf1 in the usergroup ‘Old timer’ golf1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
i'm gonna swap the alternator off the other car onto this one and see if that works then nice shiny new alternator for the gti.
![cubed in the usergroup ‘Local’ cubed in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Bump Starting it virtually every time at the moment. I've got a brand new battery, Ive secured all wiring and checked for breaks in wiring, Ive cleaned up the earth several times and added an extra strap to the srtut tower and a small one from the head. I can only think its the alternator but I'm reluctant to fork out in case its not. If I conquer it i'l be sure to let you know.
