GarytheGolf
![rnp600y in the usergroup ‘Local’ rnp600y in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
GarytheGolf
<a><img></a>
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/NK785B-1-1.jpg)
![Malcolm in the usergroup ‘Paid Member’ Malcolm in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Malcolm in the usergroup ‘Old timer’ Malcolm in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
<a><img></a>
I lifted the front of the car and mounted it on my support jig in the garage. Using the trolley jack not the crane.
![gary143.jpg gary143.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516614274/uploads/attachments/5a65b2811f2b4.jpg)
![gary148.jpg gary148.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516614277/uploads/attachments/5a65b284e01a6.jpg)
When everything is out of the way, there is plenty of access to the engine bay for cleaning / refurb.
![gary144.jpg gary144.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516614280/uploads/attachments/5a65b287cb57a.jpg)
![gary145.jpg gary145.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516614283/uploads/attachments/5a65b28aeaa76.jpg)
I gave the engine a squeaky clean and removed a few parts for access /refurb.
A single garage is very tight for storage, everything is put away for another day.
![gary149.jpg gary149.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516614286/uploads/attachments/5a65b28de6497.jpg)
Last edit: by Malcolm
In addition, I removed the footbrake bellcrank mechanism, servo & master cylinder and front brake pipes. All the cables, speedo clutch, throttle, bonnet release have been removed.
The only things I cannot remove are the fuel pipes, I can move them out of the way though.
Looking at the rear firewall of the engine bay, you can see where the clutch cable comes through. On this car there seems to be a reinforcement plate already fitted by VW. I shall have a good look to see if any further reinforcement is required.
![gary151.jpg gary151.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629169/uploads/attachments/5a65ecb03f586.jpg)
and likewise the rear brake pipes. I removed the engine looms, some went inside, the main loom (yellow plug, live and two earths) was disconnected from the fuse board and pulled through.
![gary152.jpg gary152.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629172/uploads/attachments/5a65ecb3875f5.jpg)
One of the great things about lifting the front end of the car up is the access, I did most of my work sat on a stool inside the bay.
![gary153.jpg gary153.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629174/uploads/attachments/5a65ecb616791.jpg)
Apart from general surface rust , no real problems.
![gary154.jpg gary154.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629177/uploads/attachments/5a65ecb8dd8ee.jpg)
I removed the steering rack and disconnected the gearbox linkage. So far, only noticed a few worn linkage bearings to be replaced. However the steering column gaiter has gone very brittle and will need replacing / repairing.
![gary155.jpg gary155.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629180/uploads/attachments/5a65ecbb9d89f.jpg)
The bay is ready for cleaning, derusting and paint prep. My plan: I intend to paint the bay myself, reinstall everything and get it running before the car eventually goes to the paint shop.
I destroyed an angle grinder gearbox in the process, got a free replacement under warrranty, and ended up with my drill only going in reverse. Manged to fix that myself.
Surprisingly it was mostly surface rust in the engine bay with only a bit of a split in the scuttle panel.
![gary158.jpg gary158.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629689/uploads/attachments/5a65eeb95332a.jpg)
I still have some work to do on the inside / middle of the front panel and around the lights.
![gary171.jpg gary171.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629692/uploads/attachments/5a65eebbef7fc.jpg)
Having a break eating my sandwiches I noticed that there is some more work to do.
![gary165.jpg gary165.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629695/uploads/attachments/5a65eebe83852.jpg)
With all this bare metal I needed to protect my work before the end of the day as I am unable to work on the car for the next couple of weeks, so I keyed with wet & dry, washed with soap and water and wiped down with thinners to make ready for paint.
![gary168.jpg gary168.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629698/uploads/attachments/5a65eec21d898.jpg)
![gary169.jpg gary169.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629701/uploads/attachments/5a65eec4ee4d5.jpg)
![gary170.jpg gary170.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629704/uploads/attachments/5a65eec787f90.jpg)
Engine bay sprayed with Upols Acid 8 Etch primer. Use a mask for enclosed spaces. Pretty happy with my work.
![gary172.jpg gary172.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629706/uploads/attachments/5a65eeca4ea0b.jpg)
![gary173.jpg gary173.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629709/uploads/attachments/5a65eeccdeed8.jpg)
![gary174.jpg gary174.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629712/uploads/attachments/5a65eecf96332.jpg)
![gary175.jpg gary175.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629714/uploads/attachments/5a65eed207672.jpg)
![gary176.jpg gary176.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629717/uploads/attachments/5a65eed49fcc7.jpg)
![gary177.jpg gary177.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516629719/uploads/attachments/5a65eed73a838.jpg)
As usual time to pack the stuff away. Still a mountain to climb.
![](https://vwgolfmk1.org.uk/uploads/pbextract/992289/gary179.jpg)
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
![Dubwanabe in the usergroup ‘Local’ Dubwanabe in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![dibbler in the usergroup ‘Old timer’ dibbler in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Dibbler.
Discovered the garage roof leaks now, not the best time to get it replaced. I am now covering the front of the car and engine with a tarpaulin to keep dry.
Managed to do about 4 hours today before the heavens opened, here is an update since my last entry.
Where required, the front wheel arches have been stripped and original stone chip roughed up.
Drivers side. Door post solid.
![gary183.jpg gary183.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630512/uploads/attachments/5a65f1ef25c31.jpg)
Hardly any rust anywhere.
![gary184.jpg gary184.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630514/uploads/attachments/5a65f1f25b1d2.jpg)
![gary185.jpg gary185.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630517/uploads/attachments/5a65f1f5118b3.jpg)
The only rust I could find, this has been removed and treated.
![gary186.jpg gary186.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630520/uploads/attachments/5a65f1f85cd8d.jpg)
The front wheel arches etch primed, original stone chip primed.
![gary187.jpg gary187.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630523/uploads/attachments/5a65f1fa9bcd7.jpg)
New stone chip applied.
![gary202.jpg gary202.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630525/uploads/attachments/5a65f1fd18b00.jpg)
Passenger side.
![gary206.jpg gary206.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630528/uploads/attachments/5a65f1ff82b37.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1001926/gary207.jpg)
Again door post solid.
![gary208.jpg gary208.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630530/uploads/attachments/5a65f20240236.jpg)
![gary209.jpg gary209.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630533/uploads/attachments/5a65f20542c32.jpg)
Finished off with some stonechip paint in the engine bay around the vunerable areas.
![gary203.jpg gary203.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630536/uploads/attachments/5a65f207c72b2.jpg)
![gary200.jpg gary200.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630538/uploads/attachments/5a65f20a2ff37.jpg)
![gary205.jpg gary205.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630541/uploads/attachments/5a65f20ca63bd.jpg)
Under the battery tray, inner wing and lower front valance
![gary212.jpg gary212.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516630543/uploads/attachments/5a65f20f3260f.jpg)
Pretty happy with the work done. Still have the scuttle and inside front panel to address, that's for another day.
![ianpettifer in the usergroup ‘Local’ ianpettifer in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Looking forward to getting a full day done tomorrow. unfortunately to refit the front suspension and allow the car to be removed from the garage and the garage roof replaced.
It's been some time since my last post, in that time I had to refit the front suspension and move the car out of the garage to have the garage roof replaced.
Due to weather the replacement took about five days before I could get the car back in again, the car up in the air and the suspension off again. I have had to put the engine and gearbox in the back garden under cover to gain some space in the garage.
The front has had some stone chip applied to the lower scuttle panel and coloured for protection, I intend have a professional respray done at a later date.
![gary238.jpg gary238.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631111/uploads/attachments/5a65f44678b8a.jpg)
The paint has also been applied in the engine bay, quite a few coats using cans with the clear laquer on top. The finish is not bad with only a few runs that can easily be covered up with a loom or engine or two.
![gary239.jpg gary239.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631115/uploads/attachments/5a65f44a5908d.jpg)
![gary242.jpg gary242.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631118/uploads/attachments/5a65f44d8b55b.jpg)
![gary243.jpg gary243.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631120/uploads/attachments/5a65f4501abde.jpg)
![gary244.jpg gary244.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631123/uploads/attachments/5a65f4530485f.jpg)
![gary246.jpg gary246.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631126/uploads/attachments/5a65f4557f9ff.jpg)
So far I have focused on the steering rack and wishbones. The steering rack has been checked for wear including the track rod ends. The gaiters are OK. The usual squeaky clean and POR 15 treatment followed by satin black paint.
![gary236.jpg gary236.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631129/uploads/attachments/5a65f4584a6ee.jpg)
![gary250.jpg gary250.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631131/uploads/attachments/5a65f45af3250.jpg)
The knuckle joints initially looked OK, but once cleaned one was quite loose, so I decided to replace both of them. The rivets were drilled out, wishbones refurbished and the new joints refitted with bolts.
![gary247.jpg gary247.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631134/uploads/attachments/5a65f45d8f16a.jpg)
![gary248.jpg gary248.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631136/uploads/attachments/5a65f45fc6369.jpg)
I also refurbished some of the gear change components, plus purchased a linkage recon kit from ebay.
![gary249.jpg gary249.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631138/uploads/attachments/5a65f46254364.jpg)
The car is 4 speed and I have a 5 speed box which I intend to fit. Later 4 speed cars seem to have similar linkages to the 5 speed with only afew differences, I have yet to source a few components.
The steering rack is temporarily refitted, I need to sort out the gaitor which is quite brittle and cracks. I have already tried to glue the breaks, the gaitor is quite expensive to replace costing £35-40 from fleabay or CQs
![gary251.jpg gary251.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631141/uploads/attachments/5a65f4650c0c8.jpg)
The wishones are refitted with new rear bushes, the fronts are OK. The front bolts are temporary, with the originals getting cleaned up.
![gary254.jpg gary254.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631144/uploads/attachments/5a65f467a86bc.jpg)
My next few jobs will be the front struts and hubs, I have got to change the front bearings as one it shot. I may have to seek a garage to replace the bearings.
I intend to retrofit front and rear anti-roll bars from a GTI, which I have already aquired, but need to drill extra holes in the front wishbones.
to be continued !
![Avatar](https://i515.photobucket.com/albums/t360/Rafflesmk1/DSC01993-1-1-1.jpg)
![Raffles in the usergroup ‘Paid Member’ Raffles in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Raffles in the usergroup ‘Old timer’ Raffles in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://i515.photobucket.com/albums/t360/Rafflesmk1/123-3-1.jpg)
![Avatar](https://lh5.ggpht.com/_epH8fNf49x0/TB0mY6DcK4I/AAAAAAAABqo/5ZwStPu4wY4/s128/Copy%20%282%29%20of%2037301_408840263157_568808157_4315406_4057276_n%5B1%5D.jpg)
![krasi1 in the usergroup ‘Regular’ krasi1 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I'm just delighted, congratulations for good work .
Greetings from Bulgaria..
![Avatar](https://i778.photobucket.com/albums/yy70/golf1978/46554.jpg)
![Baljulji in the usergroup ‘Local’ Baljulji in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Your approach to this car is very professional and Im rescpeting that kind of job! :clap:
Very nice mate :cowboy:
Das Gnoj 1,1L 1978.
FEEL FREE TO VISIT US ON www.golfmk1.com.hr
![](https://i1052.photobucket.com/albums/s451/baljulji69/IMG_8124.jpg)
![](https://i1052.photobucket.com/albums/s451/baljulji69/IMG_8593.jpg)
I have been focusing on the front struts and the wheel bearings. I managed to separate the front wheel hubs with the pullers I had and refurbished the bearing carriers and stub axles.
Then took a members advice and had the new bearings fitted by an independent VW specialist garage during the week at a cost of £30. half an hours work nowadays.
One word of warning though, a few days after they had been fitted, I realised the disc backing plates had been fitted the wrong way around, the discs and wheels would never fit on the stub axlle flanges.
I had partially assembled them myself, my error was not noticed by the garage before fitting the bearings. This caused some lost of sleep when I realised the error late Friday night.
I managed to rectify the situation Saturday morning by cutting the disc backing plate near the front caliper mounting and rolling the metal each side like a can of spam opener to allow the disc backing plate to be removed over the hub bearing carrier. They then could be fitted the right way, unrolling the metal back into position with some manipulations of a pipe wrench.
The front struts were stripped and the innards taken out. The strut holders, springs and caps were derusted, pickled and por-15'D. The strut and wheel bearing holders were oversprayed with satin black.
![gary256.jpg gary256.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631512/uploads/attachments/5a65f5d829ecf.jpg)
![gary260.jpg gary260.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631515/uploads/attachments/5a65f5db5d30c.jpg)
The springs have to be compressed quite alot to allow the strut to be re-assembled with all of its components.
![gary262.jpg gary262.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631519/uploads/attachments/5a65f5de5cf83.jpg)
New strut inserts have been fitted with new top bearing kits.
![gary263.jpg gary263.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631521/uploads/attachments/5a65f5e13f752.jpg)
![gary265.jpg gary265.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631524/uploads/attachments/5a65f5e3b649a.jpg)
The struts and wheel bearing carriers are assembled and installed onto the car with the wishbones. The wheel bearing kits I bought came with some nice new bolts & nuts for assembly, very useful.
Note the disc backing plate now fitted the correct way around !! Camber and alignment checks will be left to another day.
![gary266.jpg gary266.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516631526/uploads/attachments/5a65f5e60a5f9.jpg)
Maybe next weekend, I can get the car back on the ground.
![gary268.jpg gary268.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633549/uploads/attachments/5a65fdcbb7f91.jpg)
Halfords caliper paint. I use this all the time.
![gary269.jpg gary269.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633551/uploads/attachments/5a65fdcf33733.jpg)
![gary270.jpg gary270.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633554/uploads/attachments/5a65fdd1d9954.jpg)
![gary271.jpg gary271.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633557/uploads/attachments/5a65fdd4d6ba5.jpg)
What miserable weather for a Bank Holiday! I decided to take over the dining table, with a few worried looks from the wife, to re-assemble the calipers.
I was able to get new seals from ebay, however the external piston boots supplied were a slightly different shape. I was able to re-use the original boots after cleaning.
I was quite amazed how the parts all came up, particularly the pistons, guide pins and the anti rattle springs. Clean everything with methylated spirit before assembly. I had already assembled the rubber and plastic sleeves back into the caliper body
![gary273.jpg gary273.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633562/uploads/attachments/5a65fdd9e93ba.jpg)
I was able to get the red rubber grease or assembly paste. In addition the mechanical green grease for the guide pins and good old copper grease for the threads.
![gary278.jpg gary278.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633565/uploads/attachments/5a65fddcb6584.jpg)
![gary287.jpg gary287.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633567/uploads/attachments/5a65fddef36f2.jpg)
I always buy new tools as I need them.
![gary275.jpg gary275.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633570/uploads/attachments/5a65fde1503e3.jpg)
The red rubber grease is used for all those parts incontact with the brake fluid.
![gary279.jpg gary279.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633572/uploads/attachments/5a65fde40ae7c.jpg)
After fitting a new seal, use the tool to wind the piston back in.
![gary280.jpg gary280.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633575/uploads/attachments/5a65fde6c29ca.jpg)
The external boot fits over the piston and pushes into the caliper housing. Put a little extra grease in the boot to keep the moisture and dirt out.
![gary281.jpg gary281.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633577/uploads/attachments/5a65fde93e9d6.jpg)
Assembly of the outer mounting with the guide pins. Guide pins are installed with copper grease to ease later dismantling as required.
![gary282.jpg gary282.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633580/uploads/attachments/5a65fdebc82b4.jpg)
Green mechanical grease for the guide pins, this grease is not for use with brake fluid.
![gary289.jpg gary289.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633583/uploads/attachments/5a65fdeed84f5.jpg)
![gary286.jpg gary286.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633585/uploads/attachments/5a65fdf14ddc1.jpg)
You can see that these calipers are the MkII Kelsey Hayes type. I believe that these where also used on the Mk 2 Golf and could accept GTI vented discs.
![gary290.jpg gary290.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633588/uploads/attachments/5a65fdf3dcf02.jpg)
![gary291.jpg gary291.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633591/uploads/attachments/5a65fdf682d7e.jpg)
All assembled and ready to fit on the car. It's still raining !! maybe tomorrow!. I am happy with my work today.
![gary292.jpg gary292.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1516633593/uploads/attachments/5a65fdf8edd63.jpg)
