Hi Folks, any advice??
(In Topic #117229)
![Mattster in the usergroup ‘Newbie’ Mattster in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I'm new to this scene, although not to VW's in general as I own a 1990 T25 camper & a mkIV Golf estate diesel
Sorry for all the questions, I told you I didn't have much knowledge 8O . Ihope you can offer some advice.
Ta,
Matt
![studs in the usergroup ‘Paid Member’ studs in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![studs in the usergroup ‘Old timer’ studs in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I'll try to answer your questions.
white milky film in any engine is bad, it's because water is contaminating
the engine oil. As for the doors, it could mean the car has been in an accident or like my mk1 the door was caught by a gust of wind and just needs realining.
vw engines fit in a number of different models, so a replacement engine could have come from another model.
hope this helps.
Thanks for the reply. Is the water contamination a fixable problem, or is it beyond repair?
Ta
Matt
![rnp600y in the usergroup ‘Local’ rnp600y in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
white gunk is sometimes caused when a car it sat for some time or only doing short trips (old fiestas suffer badly with this )
door gap could be where door has been lifted to get it to close
hope this helps
luke
<a><img></a>
there is lots of helpful imformation and mk1 owners on this website.
That may have put my mind at rest a little.
Matt
![Avatar](https://i722.photobucket.com/albums/ww230/zambeaky/untitled.jpg)
![zambeaky in the usergroup ‘Old timer’ zambeaky in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
http://www.vwgolfmk1.o…viewtopic&t=61710&start=0
GOLF MKII GTI 8V - sold
GOLF MKII DRIVER - ex took it
GOLF MKII GTI 16V - scrapped
JETTA MkII GTI 8V LMT EDTION
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20200305_113915.jpg)
![Diesel-dubber in the usergroup ‘Local hero’ Diesel-dubber in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Re: Hi Folks, any advice??
I think most of the Scirocco engines are exactly the same as some of the Mk1 Golf models, like the 1.8 carb engine for example, so it would be a straight fit and 'like for like', hence why you've come across a couple that have been used as a replacement engine.
The door drop is really common for the age of these cars. Can be lifted by hand or with a jack for a crude quick fix (lots of us have done it)or new door pins can be put in. The other reason for an uneven panel gap could be a pattern/non VAG front wing which doesn't fit as well as the original.
There's a helpful Cabrio buyer's guide on the Home page. Good luck in your search for a Cabby. Feel free to ask for more advice around the forum. :mrgreen:
Matt
