POR-15? what does it all mean!
(In Topic #117038)
any help would be much appreciated
thanks
Mostly used for under the car
check out Homepage - Frost Auto Restoration Techniques they do the various bits. i recomment the '6 pack' of por 15 they do, 6 small tins. The stuff goes a really long way, and you dont really want to seal up a tin half way as it can dry out and/or the paint seals the tin shut
I love the stuff, the metal ready will eat rust liek no tomorrow and the paint is just awesome. Dries nice & hard and slaps on lovely with a brush, check my MK1 cabby project thread to see what kind of results you can expect
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=46506&postdays=0&postorder=asc&highlight=garythegolf&start=30
I try to remove the rust / rough bits and prepare it with the marine clean and metal ready products supplied by the same company for good adhesion.
After painting the rear beam with POR-15, I oversprayed it with a black satin spray paint from the Motor World /Les Smith shop. I think the end result is quite acceptable, it almost looks powder coated.
POR15 do suggest that you can use a primer on top of POR 15 to allow another paint finish to be applied. I also read elsewhere that you can paint over the POR15 with another finish when it is tacky, which is what i did on my suspension struts. I left the springs gloss though for contrast.
POR15 rust prevention paint does not have UV protection and should not be left exposed to sunlight without an additional layer of paint applied on top, such as Chassis Black paint or in my case satin black paint. You can leave it as it is for components underneath the car.
the paint side of the build is realy the only part im worried about as i know nothing if im wrong for thinking about using po5-15 what should i be using?
the actual paint i will be leaving to an expert but as its a budget build id like to do all the filler and prep myslef also whats a good stone chip to use for the underside of the car?
paint
I am surprised that you had a satin finish, mine was gloss. I then overpainted with satin black.
With respect to the original enquiry, I would confine the use of POR 15 on those areas where the finish is not important, i.e. underneath the car /bonnet, etc. I would use the normal paint preparation, i.e. etch primer plus top coats, for those finished areas, i.e. body, panels etc.
paint
Use the link below, POR 15 chassis black paint is supposed to be applied over POR 15 Rust Prevention paint. The POR 15 Rust prevention paint has to be applied over bare metal prepared using POR 15 marine clean and metal ready treatment.
Applying any POR 15 paint over zinc primer instead of bare metal is severley reducing the adhesion properties of the POR 15.
To get the best adhesion, either use POR 15 products and their recommended preparation processes or use zinc primer and the appropriate top coats. Do not mix the two paint processes.
For info, there are many paints around mow which are directly applied to bare metal, I have recently used caliper paint and Exhaust / Manifold very high temp paint. Using zinc primer before applying any of these paints would have reduced the adhesion properties.
Hope this helps
http://www.frost.co.uk/item_Detail.asp?productID=8202&frostProductName=POR15+Chassis+Coat+Black+%28473ml%29&catID=24&subCatID=37&FrostCat=Painting&FrostSubcat=POR-15&ref=champ
Once I've scraped the underseal off the underside of the car, I've got a mix of bare metal and the light grey VW primer on the surface. Do I need to get rid of all the paint to apply POR15 or just do the prep with metal ready and the cleaner stuff?
Once I've POR'd it, I'd like to cover with underseal to act as stonechip, sound deadening and general protection. Will this adhere to the POR15 ok?
Any help appreciated
http://www.frost.co.uk/item_Detail.asp?productID=9306&frostProductName=Chassis%20Painting%20Kit&catID=&frostCat=&frostSubCat=&subCatID=
"This neat kit allows the progressive painting of the chassis and running components without waste. Contains three 118ml cans of POR-15 Black Rust preventative Paint with three 118ml cans of Chassis Coat Black. "
How Do I Use POR 15 Rust Preventive Paint?
POR-15 RUST PREVENTATIVE PAINT
PLEASE NOTE: This product is unlike any other paint or coating you may have used in the past. Please take the time to carefully read the instructions from beginning to end before using POR-15.
Product Description
POR-15 is a rust preventative paint designed for application directly on rusted or seasoned surfaces. It dries to a rock-hard, non-porous finish that won't chip, crack, or peel, and it prevents rust from re-occurring by protecting metal from further exposure to moisture. POR-15 is sensitive to UV light (sun) and must be top coated for prolonged exposure to sunlight. Top coating not required for areas not exposed to sunlight.
Application Procedures
Rusted surfaces are best; seasoned metal and sandblasted surfaces are also good. To coat smooth metal surfaces; use POR-15 Metal Ready to prepare surface before painting. Surface must be dry and free of grease, oil, or other foreign substances. Use of "rust converter" products is not recommended as they may affect bonding of POR-15 to metal. POR-15 likes to adhere to surfaces with "tooth" rather than smooth, glossy surfaces.
STIR CONTENTS THOROUGHLY before painting. Do not shake. Refrigerate unused portion of POR-15 for longer shelf life. Apply in thin coats, 2 to 3 mil thickness. Topcoat when first is dry but with slight remaining finger-drag, usually 3-4 hours.
Spray Application
Use 30-35 lbs pressure for normal gloss. Reduce pressure for lower gloss (20-25 lbs). Thin only with POR Solvent, if necessary. If topcoat to be done at later date, apply light dustcoat of primer over tacky POR-15 and let dry. Full priming and finishing can be done later. To topcoat a cured POR-15 surface, wet sand with 600 grit until gloss is dull, then paint. Use POR-15 solvent or lacquer thinner for clean up, which must be done before POR-15 dries; once dry, POR-15 cannot be removed by solvent. Avoid skin contact. Remove from skin at once to avoid temporary staining. USE OF GLOVES AND VENTILATING EQUIPMENT IS STRONGLY RECOMMENDED.
NOTE: organic vapour particulate respirators, NIOSH/MSHA approved, must be used when spraying POR-15. Moisture will shorten the life of unused POR-15.
The statement is trying to amplify that the adhesion qualities of the paint are best over rusted surfaces.
I on the other hand always like to remove the rust and original paint if possible.
It is a serious product and excellent if you are unable to replace a rusty item. Buy a starter kit, you will be amazed if correctly applied with the instructions.
See my project below. I used it on the petrol filler pipe, tank, rear beam, rear brake drum back plates and more.
The Mk1 Golf Owners Club
P.S. I am in no way connected to the suppliers of the product, however I think I might apply for a job.
Good idea i think you could well become a sales man for this :wink: but seriously i wouldnt have a problem putting it on a rusty rear beam for instance as the metal is quite thick, but not on body work where the rust needs removing in my opinion.
Anyone put underseal over POR15?
