help needed - flashing light - what is it ?
(In Topic #113187)
![cakewalk in the usergroup ‘Newbie’ cakewalk in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I have a 1990 cabriolet & the red light under the temp gauge is flashing. What does thi smean. There is lpent of water, oil, petrol etc. It flashed straight away so it can't be temerature
T
the control relay is 42 or 43, and clipped above the fusebox, take the relay out and this will disable the level warning completly, if light persists then its the temp sensor or the clocks
![jonnosuzie in the usergroup ‘Newbie’ jonnosuzie in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
My temperature light is doing exactly the same thing. My temperature gauge works just fine. There is plenty of coolant. Ive tested the sensor and that appears to work. I have removed the relay and the light kept blinking away.
Now for the tricky part….
I turn the ignition on and leave on for about 1 minute, then start the engine and the light goes out…
Im going bald through scratching my head over this one!!
any help appeciated!
Jon
my mates pre 90 MK2 (uses same level sensor relay) did exactly the same thing. Dash gauge worked fine, just the light. Tried everything, then eventually swapped in another sensor, sorted! No idea why this would cause the problem yet the gauge would still work, but hey ho!
