mk2 golf engine and gear box in a mk1?
(In Topic #115847)
![nathbarb_red_cab in the usergroup ‘Regular’ nathbarb_red_cab in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
just been to collect my mk1 1600 engine and box.
when i got there its from a mk2 and they was not even sure if it was a 1600 or 1800.
nice ay!
it was a 3 hour drive so i came back with it anyway and plus it was a ebay buy so no choice.
what do i do about fitting (mounting) it?
and also can i use the gear box thats come with it? (its a green end cap box) and will my drive shafts fit or not?
thanks
nathan
82 cabby bits needed
either way engine will drop into a 1.5-1.8 mk1, gearbox will also work but if its got 100mm flanges either need to swap on 90,mm ones or fit 100mm driveshafts off a late scirocco or cabrio
it is a carb engine yes.
what do i do about mounting etc as i dont have the old engine from my car, i dont know what im ment to be getting
thanks
nathan
what you need is the driver side engine mount from a 1.5-1.8 mk1/cabby/scirocco, and both of the gearbox brackets from a 1.5-1.8 manual 5 speed mk1/cabby/scirocco
if your car was originally a 1.0-1.3 the driver side bracket needs choopping off the chassis leg and moving, plus if a 1.0-1.3 or an auto the stewering rack needs swapping for a 1.5-1.8 manual mk1/cabby/scirocco
any idea where i would get what i need from?
sorry to be a pain.
its hard for me cause i dont realy know what im looking for lol
thanks
nathan
just say:
'could i have all the engine mountings required to fit a 1.5-1.8 8v engine & 5 speed box to a 1.6 MK1 Golf'
and also ask about 5 speed golf gear linkages & shifter if you dont have these already, in particular there is a linkage piece bolted onto the MK1 gearbox which you'll need, as the MK2 piece is different, plus all the plastic ended rods etc.
If you look at the mk2 box you'll see an L shaped linkage with 2 ball ends, its this bit that needs removing and swapping for a MK1 equivilant item
if i get stuck i will pm you if thats ok?
thanks for your help
nathan
![lucky65strike in the usergroup ‘Local’ lucky65strike in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![](https://i452.photobucket.com/albums/qq250/lucky65strike/Kay/_MG_1945-1.jpg)
has anyone or can anyone take some engine mount photos or have a look on ebay and point me towards what i need
thanks
nathan
