fuel relay
(In Topic #115171)
![wooly37 in the usergroup ‘Regular’ wooly37 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
fuel relay
![djgail in the usergroup ‘Regular’ djgail in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
rubjonny said
you cant really as it needs a rev counter feed to trigger. if you bridge the 2 large pins on the relay socket together and the fuel pump runs you know the wiring to the fuel pump plus the pump itself is ok![]()
how do you bridge the two large pins
and then push into the slots on fuse box.rubjonny said
thick bit of wire with a spade connector on each end![]()
sorry if a bit thick
good news i bridged it and could hear the pump come on.rubjonny said
yes, into the slots where the 2 chunky relay pins fit![]()
then took three relays to have them checked at a auto electrics centre they said they seem fine.
but when they are in the car the pump does not come on any help would great.
yes number 62 and 63rubjonny said
do they have any numbers on the front or vw part numbers on the side?
I am assuming you're running this car on the original k-jet managment right, its not a 16v or something random?
the rev counter was ok before it shut down just speedo was out.
(are the connections on the coil the right way round, the red/black & green wires run to terminal 1 or -ve side of coil, the black wires run to terminal 15 or +ve side of coil ) sorry which coils in side the relay :?
breakdown guy sprayed start up and the car fired up so i think ignition is ok would that be rightrubjonny said
no sorry the ignition coil in the engine bay!
ooooooooooorubjonny said
ignition yes, but the relay requires a rev counter signal to trigger. if say the red/black wire had fallen off the coil the ignition system would still be fine and car would run on easy start, but the rev counter signal to fusebox would be gone which would stop the relay from triggering
![SEAN1151 in the usergroup ‘Old timer’ SEAN1151 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
The pump comes on if bridged put still no start checked all fuses they are fine should i check the back of fuse box
got one of those multimeters how do i check the liftpump is receving a feed.
Thank you to everyone one who as help so far.
this forum is the best.
Also, in general the +ve side of the coil has 3 spade pins on, and the -ve has 2. not always, but usually!
