Starting problem
(In Topic #113863)
![Futch in the usergroup ‘Regular’ Futch in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Starting problem
My Citi has developed a strange problem when I try and fire her up.
On Friday I was due to leave work, and got into the car to start her - all clocks/dash lamps etc. where fine. As I turned the key in the ignition, all the lights and LED clock etc. vanished, and she had no power at all. She wouldn't turn over, it was as if the battery was totally flat.
I have a relay mounted in engine bay for the full beam lamps, and it has what appears to be an earth wire under it, bolted to the wing. When I fiddled with this the power came back on and the car started.
I'm not sure what this earth is for, or why it interferes with the starting of the car, but she did it again this morning, though very quickly and fired up at the second key turn.
Has anyone else experienced this?
96' Citi Golf 1300.
Thanks!
Matt F
1996 Citi Golf Chico 1.3
![mrpurple in the usergroup ‘Paid Member’ mrpurple in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![mrpurple in the usergroup ‘Local’ mrpurple in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
You where spot on!
The earth from batt neg to chassis was rusty and gunked up - took it all off, wire brushed and bolted back together and all is well.
Is there anything I can put on the earth to prevent future corrosion?
Someone mentioned vaseline!?
Matt F
![M7R in the usergroup ‘Old timer’ M7R in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![](https://img.photobucket.com/albums/v90/mini7racer/DSC_0051ED-Copy.jpg)
