economy gauge & MFA
(In Topic #113448)
![bamba in the usergroup ‘Regular’ bamba in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
economy gauge & MFA
![SEAN1151 in the usergroup ‘Old timer’ SEAN1151 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
if anyone reading this can advise??
you need to remove the knee tray under the steering wheel and get your hand in behind the clocks to see if the pipe is attached,its only thin,comes from the vacuum pump attached to the dizzy
removing the clocks 1st time around is fine,its putting everything back thats a nightmare
Life Member
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=29534
If the 5 pages or so are enough, have another look in the FAQ section at the bottom of ther forum because this subject comes up time and again.
Dan
Life Member
Many thanks for your help,
Website Manager
bamba said
any idea where the connection is on the gear box?
Part of this part in this post https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=electrical-faq_2%2Fgsf-reversing-switch_2
Good luck , your gear linkage maybe to blame if it is not adjusted correctly you will never switch the 5th gear switch if it is . Try a fiddle with the gear stick [gently] while on the move , push pull etc , the econ guage should rise .
