Floppy accelerator - disintegrated rubber
191 721 559 - 0.64+VAT
Life in the French Alps: <a href="Le Franco Phoney: All things French in La Clusaz, Annecy and Haute Savoie">www.lefrancophoney.com</a>
'89 Clipper Cabby
A few people have said the Mk II part is the same. The VW parts guy said not, but it is true that the part for the Mk II is 64p compared with over a fiver for the Mk 1.
Here are the two bits compared:
The Mk II part is smaller, has a larger hole in the middle and is chamfered on one side. It explains why people who went for the Mk II bit often seem to end up looking for a circlip or something to stop the cable pulling through!
2008 Citro'n C6 (C6 RTK)
1993 Jeep Cherokee. 1985 Scimitar SS1
132 cars in 18 years…
Past VWs: Mk 1 Clipper, Mk 2 Polo, Beetles, Beetle Cab, Buses, Passats, Sciroccos, Golf Mk 2 GTis, Jetta Syncro, New Beetle Cabrio
last of all you need to set the cable adjustment so as its flat to the floor, the throttle has just hit the stop. if you set it too tight you'll end up bending the pedal arm and cable!
low, and slow.
Cheers, jj
Anyone need Air-Con or Refrigeration drop me a line….thats my business! IMG_0245.jpg Photo by jjrobb | Photobucket
