Where to get technical specs for.... Mk1 Gti fuel pump
(In Topic #112563)
![TomGti in the usergroup ‘Newbie’ TomGti in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Anyone know where I can see tech specs of oem fuel pump for Mk1 Gti?
(Or let me know what pressure it supplies)
So I can decide what pump to get to replace it with (Will replace fuel pipes between fuel tank and fuel metering head at same time)
"When I bang my hand on the dash, check for valve bounce."
Re: Where to get technical specs for.... Mk1 Gti fuel pump
TomGti said
Finding the whole lot brand new seems excessively unlikely.
Its only unlikely, if you don't look! The standard VW parts are readily available. If you flick through Practical Classics, you'll see 5 stars next to parts supply, or whatever.
10 bar 750cm3/min I think….you'd need to match up the fittings too.
10 bar - blimey I'm surprised… The fuel pump next to rear right wheel next to accumulator yes?
I'd be shocked If I could get a new set of pipes and pump and accumulator for less than the price of replacing the lot - unless the pump really is @10 bar… That's more than I expected.
(AFAIK, the fuel hose I get from the local shop is 10 bar - even for carb applications… never understood why)
![GrimyFingers in the usergroup ‘Local’ GrimyFingers in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
There is a company on the Internet from the UK which sells replacement pumps at a fair price, but I can't recall the name right now.
