16v TO 8v HELP...
(In Topic #111618)
![Avatar](https://i637.photobucket.com/albums/uu94/DUB50K/AXLWAYCA5T6Z3CCASDL49DCAJATD5XCA5PA.jpg)
![DUB50K in the usergroup ‘Regular’ DUB50K in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
16v TO 8v HELP...
thanx
any help would help more than you know
to fit 2l 8v to mk2 you need to change the manifold, then all the engine loom for 8v k-jet/digifant as you'll need all the 16v bits for the mk1. then you need a custom mk1 16v manifold/downpipe setup.
if you want to run 2.0 8v in mk2 i'd fit mk2 8v head, and digifant loom from a pre-90 GTI. 8v manifold will fit existing downpipe so zaust can be left on at least, hack up the 16v metering head feed/return lines to get the barbed fittings out of them, these fit on the 16v under car lines and the digi pipes will push straight on.
![](https://vwgolfmk1.org.uk/uploads/pbextract/947056/download-1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/947056/download-2.jpg)
What ya think?? it'll work? looks like its actually just held to the hub with 3 studs :dontknow: how do i get it centric anyway
cant say either way if that would be ok or not, I'm no engineer! Looks like it is at least hubcentric so it should centre ok. If its centred properly there should be no shear forces on the bolts, its all about clamping pressure and friction!
