1990,1.8,karmann clipper/alpine white
(In Topic #111193)
![Avatar](https://i722.photobucket.com/albums/ww230/zambeaky/untitled.jpg)
![zambeaky in the usergroup ‘Old timer’ zambeaky in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
<img%20src="https://vwgolfmk1.org.uk/uploads/pbextract/942741/018-2.jpg"%20title=""%20alt=""%20/>
these wheels just had to go!!!
<img%20src="https://vwgolfmk1.org.uk/uploads/pbextract/942741/019-2.jpg"%20title=""%20alt=""%20/>
MY PROJECT BEGINS……….
record of all iv done to it so far from purchase date till present date'
a dam good polish
new front windscreen (2009)
replaced missing hand brake cover
new strereo
took the 14" wheels off put my 15" on
had the sender & housing replaced for temp guage (2009)
new vw grill badge ( nice & shiny now )
new rear brake cylinders & pads (2009)
new starter motor (2009)
german metal pressed plates
painted rocker cover (2009)
rocker cover gasket (2009)
head lamps (main beam)
wolfburgh door lock pins
wolfburgh window winders
mk1 owners club grill badge
original heated washer jet fitted (2009)
boot lock seal (2010)
rocker cover breather hose (2009)
front passenger wing side strip (2009)
stainless steel polished wing bolts (2009)
stainless steel polished radiator hangers (2009)
stainless steel polished bonnet catch bolts (2009)
stainless steel polished grill bolts (2009)
new header tank cap (2009)
bonnet earth strap (2009)
VW mudflaps (F & R) (2009)
new oil filter & oil (2009/10/11/12)
bosch super 4 spark plugs (2009)
new second hand radiator cards (2009)
new seat runner guides x4 (2009)
inlet manifold seal washer (2010)
flange-carb>maninfold (2010)
water flange seal x2 (2010)
head weld & steam bath (2010)
head skim (2010)
oil filter (2009/10/11/12)
timing belt 2010
timing belt tensioners (2010)
cylinder head gasket set (2010)
cylinder head gasket (2010)
valves ground & re seated (2010)
valve stem seals (2010)
refurbed & painted wheels
steering boss & ignition dash trim (2011)
BBS ra'S itted (2011)
new lifters fitted (2012)
new brembo disc's & pads (2012)
replacement items i managed to get……(in garage for when needed)
speedo grommet (new)
x1 water pump (new)
full set of polly bushes & clamps (f&r new)
x2 front wheel bearings (new)
x1 rear wheel bearing (new)
21 Hella headlamp…. (changed them recently to patern part lamps as one of the hella lamps was cracked, kept the good one so now i have a mint pair of originals to put back on)
x2 sets of front vented disc pads (new)
x3 engine mounts
x1 Hella fog lamp
x1 door lock barrel & key (new)
x1 fuel filler cap & key (new)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/011golfmk1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/008golfmk1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/009golfmk1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/010golfmk1.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/016clipper.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/015clipper.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/014clipper.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/002cabrio.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/004cabrio.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/942741/003cabrio.jpg)
GOLF MKII GTI 8V - sold
GOLF MKII DRIVER - ex took it
GOLF MKII GTI 16V - scrapped
JETTA MkII GTI 8V LMT EDTION
spudfingers
![parker1979 in the usergroup ‘Local’ parker1979 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
let me no a date and time and i can meet up somewhereparker1979 said
very nice indeed, yeah you deff gotta come to the MK meet
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=61405
its next tuesday the meet isnt it?
![Avatar](https://i116.photobucket.com/albums/o17/the_parrs/Honeymoon/PICT0071.jpg)
![ant5 in the usergroup ‘Paid Member’ ant5 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![ant5 in the usergroup ‘Regional Hosts’ ant5 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![ant5 in the usergroup ‘Local hero’ ant5 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Looks as though the car is standard ride height, they all tend to sit low on the rear, As you are on 15's this is the probable the cause of rubbing. (originally it should be 14's).
The best bet would be to measure it up against Parkers.
You may find the rear shocks are just a little tired but not knackered :dontknow:
See you at the MK meet
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2019 Skoda Octavia Sport ( it’s Golf)
fluid leak
![](https://vwgolfmk1.org.uk/uploads/pbextract/945477/001brakefluid.jpg)
Spudfingers said
Hope you get that patch sorted bud! Let us know…. and a cabby in this weather… it's made for it :wink:
will do, got a bit ahead of myself the other day thought it was this tues i was goin to the meet wiv u but realised got another wk to go , lookin forward to it, just as well really it is nxt wk jus incase the garage need the car for a day or two 2moro to fix wot ever it is leaking
yeah ok sounds gud :wink:Spudfingers said
I'll pm you my number mate. Then we can decide where to meet before heading off!! :wink:
wet patch
