Replacing a Pierburg carb with manual weber
(In Topic #93786)
![concunningham in the usergroup ‘Local’ concunningham in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Questions
What do I change to?
What should I pay new/2nd hand?
How hard is it to do yourself?
Is there anyway to service/overhaul the Pierburg before splashing the cash?
Con
![andy77 in the usergroup ‘Paid Member’ andy77 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![andy77 in the usergroup ‘Regional Hosts’ andy77 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![andy77 in the usergroup ‘Old timer’ andy77 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
http://www.clubgti.co.…m/showthread.php?t=144497
http://www.clubgti.com…hlight=weber+32%2F34+carb
Ebay is a good place to look for the carb, just make sure you DEFO get all the brackets and the manual choke cable assembly, plus a weber service kit, basically new gaskets etc (also from ebay, just do a search for them) also make sure the weber is jetted correctly for your engine ie for a 1.6 or a 1.8 as the jets are different sizes !
Also search on here for help
Plus fit a new inlet manifold rubber flange as you defo dont want any new air leaks.
I'm also fitting a new accelerator cable at the same time.
hope that helps !
G60
Anyone done a 1457cc?
![littlerolf in the usergroup ‘Old timer’ littlerolf in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Yorkshire Region Host
Mk1 Cabriolet 1500 (under resto)
Mk1 GTI
Mk1 GTI
I had the carb off and cleaned it up and checked all the hoses. It seems OK. Might try the service kit though. For that price you can't loose.
I put it all back together and hey presto it ran. Today no start. I think I might have the leads in the wrong order as well.
sh*t
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/dog.png)
![Concorde_Rules in the usergroup ‘Local’ Concorde_Rules in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Can webers be automatic as well as manual? Cheers
search for carbs you'll find his shop
![mk1ash in the usergroup ‘Local’ mk1ash in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
it was from some weber shop on the net
just type in weber see what you get . hope that helps a bit
![chrissyboy in the usergroup ‘Regular’ chrissyboy in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
fitting a weber
mk1 work in progress
Can you post up a pic of the carb in place ?
Could also try a search on the forum !
G60
![:P](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cheeky.png)
also on the weber there seems to be a little rod that isnt connected to anything and when you press it in it stalls the car is this the problem why my cars cutting out when i let the revs die down????? :cry: :cry:
As for the Little Rod im not sure what you mean soz post a pic of it if you can ?? cheers
G60
![](https://vwgolfmk1.org.uk/uploads/pbextract/780112/LardyBoy010.jpg)
This one below shows how i've just re-joined the coolant hose's together on the in-let manifold, as the weber doesnt need coolant for its choke as it has the manual one!
![](https://vwgolfmk1.org.uk/uploads/pbextract/780112/LardyBoy004.jpg)
G60
the linkrod is on the left will examine tomorow when im at work anf get those pics on as therell explain it easier ta bud
G60
G60
