oil in dizzy
(In Topic #110229)
![Avatar](https://i687.photobucket.com/albums/vv240/bigstu36/ebay080-1.jpg)
![bigstu in the usergroup ‘Regular’ bigstu in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
oil in dizzy
mk1 gti 1.6,mk4 1.8t ,caddy 1.9sdi
![GrimyFingers in the usergroup ‘Local’ GrimyFingers in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Chriselias272 in the usergroup ‘Local’ Chriselias272 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Ok, some progress. Got the pin out and took apart the distributor. Used a
punch slightly smaller then the hole through the cog at the end and gave it a
good smack.
Then laid out all the parts, there are some washers that are like Dremel
cutting discs. Does anyone know what type of washer that is one, if not both
need replacing.
Then the second hardest bit was removing the washer in the lip on the other
side with covers the oil seal. As you can see from the pic (middle item) it has
a serrated edge and is quite soft. I gently knocked it out from the other side.
And the seal at the bottom, didn't look too bad but leaked alot so…
Then the shaft. Looks like there is a groove where the seal should sit about
5mm up from the bottom. Gonna clean this up before refitting.
The size i have gone for is indeed 12x19x5 and most places start 12.5mm x
22mm not 19 so it would be too big. I got some with a dust seal (left, you can
just make out the lip on the inside) and some normal seals. Got them from Simply Bearings, very good
service. Next day delivery and flat rate of postage of ?1.25!
Then i gently knocked it into the distributor, making sure not to go down too
far. I check with the shaft to make sure the oil seal lip 'clicked' with the
mark on the shaft to seal.
Chriselias272 said
you get the seal in a head gasket kit.
No. The seals for distributors are not replacement parts sold by the dealer or in service kits. The distributors are intended as replacement parts, i.e. give them your bad one when you purchase a rebuilt one. Most call it a core and there will be a core charge if you don't have the old one.
You need to measure the shaft and old seal, I don't know the size of a 1.1L distributor shaft or seal, and take that to a company who sells seals. The important sizes are the shaft, the out side diameter and the thickness.
The measurements of the internal seal are 12x19x5
![Farmerfella in the usergroup ‘Regular’ Farmerfella in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
i know its an old thread, just thought someone could clear something up for me.
Ive got the dizzy apart with the seal out, theres only 1 seal isn't there? the other 2 pieces that the shaft goes onto are just acting as bearing? Is this correct?
Also is there an oil seal or gasket for the housing the dizzy bolts into, im not sure what its called but its the part that is fixed into the head?
another quick one, the part that the end of the dizzy shaft sits into on the engine side has oil sat in there. Is oil supposed to be able to get in there or is there another seal further back?
there is another big oil seal round the outside of the dizzy that stops oil getting past the edge of the dizzy
I've got oil in that bit but it's getting into the dizzy cap aswel.
The bigger oil seal is more like an o ring isn't it? Is that the one your meaning?
Thanks again
