Revs drop and cuts out *urgentish*
(In Topic #108242)
![adz in the usergroup ‘Regular’ adz in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
If i turned the key off and on again it would be ok, or if not, i could pull over, leave it a couple of mins and it would fire up.
I replaced the
-coil
-leads
-points
-condensor
-rotor arm
-dizzy cap
-plugs
since then it had been pretty much ok until today
now when i try to fire it up the revs drop straight off and wont idle at all.
the only thing i can link to the problem if it helps to get a solution is that the green hazzard/indicator flasher LED is on constant when i indicate or put the hazzards on, even if i replace the hazzard relay.
if anyone has ANY ideas or suggestions it would be muchos appreciated as its my daily!
cheeeeers
adz
owns:
mk1 jetta 1983 blue
1966 beetle on hydros
1959 lowlight karmann ghia
mk1 jetta 1983 blue
![Madferret in the usergroup ‘Old timer’ Madferret in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Have you got some kind of immobiliser on it? From what you say it could be part of the ignition system in some way, maybe the ignition switch is faulty, to test remove the plug from the back and get one from a scrapper and plug that in.
Hope that helps and I'll work out what circuit it actually is in the mean time.
~Madferret
Mk1 1457cc 5door GX '83
what is the ignition switch? the barrel?
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
~Madferret
with the ignition on, if i hav the cap and rotor arm off, and flick the points with a scrwdriver, shouldnt it spark? it doesnt at the mo?
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
Be careful doing it though as you can get a shock, even from the LT end (green wire)
~Madferret
replaced condensor wire too.
stil no joy.
should ther be power to the coil with the ignition on?
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
but I know where your coming from, to generate the spark the 0v (ie gnd) (green wire) is switched on & off, collapsing the coil and generating a spark in the HT lead, its a crude but effective method similar to how a transformer works to charge your phone up. I think your looking in the wrong place though personally you need to look where I suggested as I know it will cause these symptoms.
~Madferret
cheers bud, where to start! lol
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
~Madferret
really appreciate your help and suggestions though bud!
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
i dont wana break anything so if anyone knows what wires/plugs i should be checking that would b great
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
~Madferret
Also do the lights work, or other ancillory items, give details of what works and what doesnt if you dont mind.
~Madferret
when i have the key turned all the way over the green led for the flashers are on constant so would this point to any kind of relay problem, are the flashers and ignition earthed the same or something.
il switch lights etc on 2moro and see whats what.
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
Hmmm one thing to try, see if you have 0v to the chassis, tested by using the resistance check from the 0v battery clamp, and then to a piece of exposed body like to the metal on the door switches or something similar.
If your getting more than 2ohm (preferably a lot less) you'll be getting problems and remember to check the calibration by connecting both leads together and noting the result.
Probably best to start with the basics and work up from that.
~Madferret
![Avatar](https://i14.photobucket.com/albums/a334/Pedrosgolf/MK1CitiSteeliesavatar.jpg)
![Peddersgolf in the usergroup ‘Local hero’ Peddersgolf in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Pete :wink:
i havnt seen the car this eve so didnt try the lights and other bits.
think i owe u a few beers at a show if we crack it
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
![Avatar](https://i245.photobucket.com/albums/gg80/novocaine10/n731220548_174194_274-1.jpg)
![novocaine in the usergroup ‘Local hero’ novocaine in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
the indicators lights can also be caused by the hazard light switch.
the revs dropping of can be crap in the fuel tank or blocked jets in the carb.
both are very common faults and are in no way connected.
and changed the hazzard relay and switch
owns:
mk1 jetta 1983 blue
mk1 jetta 1983 blue
