1.8 Turbo in Rivage, complete beginner
(In Topic #108091)
![drewpro in the usergroup ‘Local’ drewpro in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Do you think it's an achievable thing to do or is something like that really not something a complete beginner should be attempting?
Thoughts and opinions would be appreciated!
Someone who could do it for me would be appreciated even more :mrgreen:
/Users/cherie/Pictures/iPhoto Library/Originals/2008/16 Sep 2008/DSC01016.JPG
DIY is possible but if you've not removed/replaced an engine before, it will be a head scratcher for sure. There is always the walk-thru on www.fastgolf.org.uk and there's the FAQ thread here, it takes a bit of wading through though.
What sort of cost would it be to get TSR to do it?
Would like to do it myself but don't want to risk messing up my car!
drewpro said
Many thanks, it would depend where in Somerset to be honest, I have helped someone remove and replace an engine before but was literally just muscle (and not much of that to be honest)
You'd have to contact TSR. If you're willing to travel, then other firms such as:
MV Developments
Awesome GTI (Manchester)
The Phirm
+ lots I've missed out, no doubt
Could quote you too. bens_cab has also done conversions for people but I'm unsure if he's set up to do this in his new location (Kent).
![manx1641 in the usergroup ‘Regular’ manx1641 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
manx1641 said
You've got start somewhere, what is your level of mechanical skill, bolting the block in is quiet straight forward, the electrics may be tricky but have been done many times before in many ways, the plumbing is logical, if you plan it out you should be ok.
Very limited experience but i'm intelligent enough to be able to follow instructions think i'd have more trouble with technical terms
![kamdeux in the usergroup ‘Local’ kamdeux in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
original is probably easiest but may require the right keys dash and loom,
aftermarket is costly and will require tuning, but may be simpler to install,
By the way i'm no authority on 20v turbo's just in case i get some thing wrong,
As far as engines go i'm led to believe the early golf is the easiest to install but may be getting harder to find, mounts are available of the shelf from some tuning places, depending on what gearbox you go for you may need new mounts for that too,
I've got a 2.0l mk4 lump in my mk1 and fitting was no harder than fitting the original clipper engine, i just had to modify the side engine mount,
Good luck, you love it!
manx1641 said
Cool, i'd start then by thinking of which route you intend to take as far as the engine management is concerned, basically original ecu or after market,
When you say the original ecu is that the one that comes with the engine or the one in the car already? I'm assuming it's pretty straightforward to remove the engine and stick another one in but the complicated bit will be joining all the components together and getting the engine working
Hey found this on line, is it any good for following instructions are the parts listed hat i'd need?
