EX-Engine trouble! Huzzar!!!!!!!!!!!!!
![Avatar](https://www.avatarist.com/avatars/Funny/Angry-PC-User.gif)
![phatts in the usergroup ‘Paid Member’ phatts in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![phatts in the usergroup ‘Local’ phatts in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
ive gotta second the idea of the car running rich but on a complete wim, have you double checked that all your breathers a tight and havent got any cracks..?
as you do seem to be over fueling it may be worth given the mixture a 1/4 of a turn anticlockwise to lean it off… but i've also found from experience, that if you take the rubber intake off (as before to reveal the plate) whilst turning the car over, depress the plate down a little to lean the mixture off and see if she'll start/run… if she does as mine did then your running way rich and could do with a few more turns on the mixture to lean it off a bit (and i mean proper turns)
hope this helps
'69 MG Midget 1275 (currently restoring, cammed and ported head) '81 Lhasa 1600 GTi - kent GS25 (294) cam, full supersprint mani back, filter, 2.2 throttle body '82 Audi 80 Sport '97 20VT Passat (AEB with a 57i) '84 Silver Campaign - DX but AEB coming
![Avatar](https://i29.photobucket.com/albums/c293/chriswizz/new.jpg)
![chriswizz in the usergroup ‘Old timer’ chriswizz in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
…check your injectors with this…
Injector test (pdf)
That is a top guide prowler!
Thanks for all your help one and all, it will be a while before I can get back into my garage, but when I do I will try out all your ideas.
Don't want to tow the car yet, as my brakes don't work!
Going to start with the WUR then set myself up a control pressure test guage (I will knock one up at work)
I hope my boss doesnt read this forum!
www.cw-se.com
"Video et taceo"
"Video et taceo"
![cedar in the usergroup ‘Old timer’ cedar in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Used the guide on the forum, so I am pretty sure its ok.
Unless there is something else to check, mind you not doing it today,I think its -2 in my garage!
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
Chris
www.cw-se.com
"Video et taceo"
"Video et taceo"
![huw169 in the usergroup ‘Paid Member’ huw169 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![huw169 in the usergroup ‘Old timer’ huw169 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Battery sounds a bit tired so it is on charge.
Hopefully i'll get her all fired up at the weekend and then get her tuned to ensure the fuelling is right.
Good luck getting yours going……
WOT and off she goes. Will be off to work in her tomorrow.
I need to get her tuned though as I can smell fuel :cry:
I think it is over fueling - at least I hope it is by the amount I'm blowing through!!!
Tested system pressure= 78psi as per spec (How to tune&modify bosch fuel injection book)
So back to the drawing board :?
www.cw-se.com
"Video et taceo"
"Video et taceo"
paul_c said
Cracking the throttle wide open during starting will help, if the mixture is set too rich and it should start this way, but might not idle. Needless to say, you need some way of measuring the mixture (CO meter or wideband lambda) otherwise you're guessing, once its running and you can adjust it.
Have a play around with the mixture then. I'd suggest 1/2 turn anticlockwise, then try to start it. If it doesn't, leave it for around 10 mins (for the petrol to evaporate or soak away) with the plugs removed, turn another 1/4 turn anticlockwise, try again. Repeat until fixed.
It sounds like a massive saga does this engine starting job, but due to small child, full time job, drawing and other commitments, i have only spent about 3 hours on the thing in two weeks!
So thanks for all you continuing help.
Chris
www.cw-se.com
"Video et taceo"
"Video et taceo"
![joemarkey6 in the usergroup ‘Regular’ joemarkey6 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
it turned out to be the pin underneath the fuel distributor, it had somehow jammed wide open and was flooding the engine to the point where the oil in the engine had a lot of petrol in it(thats how i found out, with the smell, luckily before i blew myself up)
i had to take out the 2 screws to remove it from the air flow box and then take off the brass nut, cleaned and oiled the bits (there was a bit of grit in there ) then put it back together(i had to replace the 2 screws that hold it to the air box because the heads on them were no good
i also had to change the oil and filter again
hope this helps
Joe
Black 1992 gti cabrio sportline
Details to follow……………………………
www.cw-se.com
"Video et taceo"
"Video et taceo"
I mate of mine Daz (ex-car spark) came to give me a hand, we went through all the aspects of my engine together.
Fuel check
timing check
Air check
Everything was ok, the only question was the spark. With a plug out of the block it would appear to spark quite well, but then made no effort to ignight the fuel.
We then checked for a voltage drop between the block and earth, OK.
Untill we cranked over the engine. Then we lost 3v. Bad earth?
We then clamped some wire from the block direct to the earth, and sure enough it fired into life!!!!!!!!
The engine/gearbox is earthed correctly all joints copper slipped and paint removed, I can only assume it the paint etc, I have used in the rebuild which is insulating the block.
So it now works after 5 years and I am over the moon. Thanks for all your ideas and help.
Chris Wizz
PS, it was dam cold in the garage today!
www.cw-se.com
"Video et taceo"
"Video et taceo"
