R/H/Side Direct Action Servo Conversion
syncro said
i just got this pm from golfgod,
By the way nissan do a pwr rack that is very close to the mk1 change the tie rod ends for vw ones join the two halves of each uj joint, install a new alternator with the pump attached to its rear [no need for vw pump assemb] or if its a combo use the servo vac as well that way you allways got servo power even if engine dies!
skyline
primera etc.
so there you have it guys another piece of genius from the golfgod………..personally ive never in my life read such a half baked load of rubbish! the guy thinks an altenater with built in vac pump still provides vacumn if the engine driving it stops turning WHAT??? and think about it is it really easier to fit an altenater with built in p/s pump from say a transit, pajero etc to a golf engine and be messing around fabricating mounting brackets, tensioners, pullies and different belts rather than use a good old reliable power steering pump brackets, pullies and belts that will bolt on from another vag engine and hey golfgod a skyline rack is from a rwd car, its mounted under the sump to a crossmember not mounted to the bulkhead like the fwd bluebird rack supposedly used in the TSR conversion
i know its off topic but for anyone interested here is my toyota power steering conversion, it may be more helpful than that gem of a pm up there, i feel the need to post some usefull information on the subject to cancel out that drivel i had to read there, i cant wait to see pictures of his abs/servo install if thats his thinking behind power steering
http://vagdrivers.net/forums/index.php?s=23c558b0c168bf3685c96a44f500f60a&showtopic=20511&pid=187809&st=0&#entry187809
there are many different ways of converting to pas, the info contained in the above link was the approach i took and it worked out very well for me
I'm glad to hear I'm not the only one getting PMs - golfgod, don't PM me again, post it here to allow discussion. Thanks.
,servos, who needs them anyway, as for abs what a load of rubbish.
rob
www.keets-customs.co.uk
Join 'photobucket'- its a free image site that resizes your pics automatically for fourms like this. Its so goddamn easy peasy, even i can use it 8)
You've certainly rattled a few cages very quickly chum, best get some pics up quick so we dont all think its all a load of mooshine and laugh you off to the next forum highjack!!
bends
one for syncro
Re: bends
golfgod said
Look what are you talkin about of course you will brake on bends theres plenty of em and how will abs not help?? if it works properly it is nice why fit as standard to most vehicles?
When you are introduced to track driving, it is well established technique to get all the braking done, in a straight line, before you turn in for the corner. After you have mastered this, then you can leave the braking even later and "curl the tail" of the braking zone, to start the turn in just before you end braking. Basically, any car can brake best when its in a straight line. And any car corners best when its 'neutral', ie neither accelerating or decelerating. Then on the exit, you can apply power, and control the oversteer or 4 wheel drift, to accelerate as best you can for the forthcoming straight.
Its the fastest way round a racetrack.
Sure, in road situations, there will be instances when you need to brake and turn - the moose test is a good example here. But if we're considering a car modified, a fair amount, we can assume it is an enthusiast who is enhancing the car for track use or at least a similar sporty feel, within the limitations of driving on public roads.
For the clever
Re: one for syncro
golfgod said
oi syncro you little anarak i said if the engine dies not stops turning you just aint got a clue av ya? and you jump the gun and dont read properly.
Ill leave the fact you are braking hard enough on a bend to get ABS to kick in to one side….(unless you have very very poo tyres with a low co-eff of friction :wink: ) I think Paul has backed me up enough to prove I know what Im on with….Have you done advanced car control? - Im off for my second course on this a few weeks through work, ?1500 worth of training at MIRA proving ground in various cars and on various diff surfaces from ice to high grip tarmac….Ill ask their views on mid corner braking hard enough to get ABS to kick in and let you know what they say :wink:
From - http://dictionary.reference.com/browse/Dies
Die - To cease living; become dead; expire.
Now this means that if the engine dies it has stopped turning…so I think you will find Syncro is correct
golfgod said
paul i cant wait for you to see the pics and for you to suddenly change your attitude and want to know more and be my friend how gay is that? almost as gay as you bunch of schoolgirls worried im right sort it out paul i aint your enemy and as for the rack where it bolted originaly is niether or there this is gettin stupid
Once again, golfgod please don't PM me again.
if the mk1 braking system is set up correctly then it will works 100%
trust me.
this is way to much effort when you can buy a pedal box which will do away with the bars ect of the shelf
cant wait for my pm :mrgreen:
oh and were not all gurus but dont take kindly to idiots giving it the big um calm down a bit and read back your arsy replies then you will see who the person in the wrong
theats my 2p well spent i think :mrgreen:
I was always led to beleive ABS allows you to steer around obsticals under heavy braking and that it doesn't actually inprove the braking distance.
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
cabby18t said
still waiting for the pictures…….
dont know about you but i like to feel the pedal working and not have abs interfering with the heavy braking :wink:
Pro's and con's for both, but like you, I wont be rushing to fit it.
Graham
ABS only helps under extreme braking where it stops a wheel locking, BUT if you have good feel you can normally judge this your self by feel, plus it all depends how over active the ABS is, I have driven some cars where it cuts in very early :?
heres a how it works just incase "The Lord almighty" is reading this, and for anyone else who just wants to know
http://auto.howstuffworks.com/auto-parts/brakes/brake-types/anti-lock-brake1.htm
Re: one for syncro
so you are reduced to name calling? if im an anarack then what are you? you seem to think you know it all. im here because im a car enthusiast I want to read good solid information on this forum and learn from it and I want to contribute in a positive way, I can do without reading nonsence from the like of you
Inaris silver series 1. APX 1.8T REVO software, hybrid O2J/O2S 6 speed, peloquin diff, cabrio drives, toyota pas, 7.5x16 5X100 compomotive mo flatspokes, G60 ABS, 305 brembos octy vrs rears, coilovers and arb's by H&R
Its mildly entertaining but I come on here for MK1 stuff not a slanging match.
and yes seems the moderators are still on there xmas holidays but then lets face it not many of them come into the tech section is scares them :mrgreen:
