Project mk1 G60-New pics pg11
Pretty easy to do as half the loom you don't need
found a wicked guide which was so easy to follow.
and the big pile of left over wires
so after all the choping you are left with 5 wires that connects the whole engine loom to the mk1 loom.
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
been removing parts off the engine in my corrado tonight, getting all giddy about putting the engine in the golf
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
g60 FAQ - Read this first! | VW Vortex - Volkswagen Forum
and here is the diagram when you have got to the stage i'm at
still need some boost pipes but it runs
Nice mk1 8)
I have decided to leave it out as it makes access to the engine so much easier.
so started off by cutting it out.
I decided to get stuck in as it was a nice day.
1st job front bumper and wings off
Then started to sand and grind back the remaining bits of the rain tray
will make a start on the other side today and then rip the loom out again and hide the wiring in the inner wing
anyway done some more today so here are a few pics
However I feel I should point out something that you (and your insurers) need to be aware of.
The `rain tray` is not a rain tray. It is a raised (extended) part of the sealed bulkhead (note also the rubber on the top that seals against the bonnet) which is designed to act as 1) a fire wall between the engine bay and the car and 2) to stop fumes being drawn in via the heater etc.
As a minimum may I suggest you consider creating a metal plenum around the heater fan with a metal duct that connects to and draws air in from outside via one of the scuttle vents and seal off properly any other holes.
If you had a bad fire (in particular an electrical fire) while driving along the airflow/heater would fill your car with smoke very quickly.
Apart from that its a great build and we all learn from it :wink:
Jon`s Dad
<a><img></a>
Pulled the engine out and all the braking system
Removed the battery tray and Alot of sanding
New intercooler in place
Pair of genuine wings at last.one new one and one off a cabby
Bit of new colour
New roof thanks to chudd for this
Are you reskining the roof?
