picked up cabby... finally some pics of seats
![Avatar](https://i54.photobucket.com/albums/g82/darthpalmer/golf.jpg)
![darth in the usergroup ‘Local’ darth in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![staffords in the usergroup ‘Old timer’ staffords in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
1989 VW GOLF GTI CABRIO
1997 VW POLO 1.0L
2003 VW PASSAT TDI 130 SPORT
1997 VW POLO 1.0L
![rae_cabby in the usergroup ‘Local’ rae_cabby in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
cheers stafford i would imagine help will be needed lol
![all_whiteGTi in the usergroup ‘Local’ all_whiteGTi in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I've replaced my side tensioners also. It's a good idea to tie some string to both ends of the cable incase it dissapears back inside the roof when you close it. Half open the roof so you can flex the sides allowing the cables free passage when you insert them. I used a long, thin, stiff but flexible plastic tube to push through the roof with the string attached to the end (the tube was that normally attached to a brush for cleaning the pipes on a home-brewing kit!), which means when it comes out the other side I could pull the string and pull the cable into the roof. It's much easier than trying to push the cable itself through the roof with it's rounded end. Lube up your tool (oo er) before you insert it into the roof too, but not with vaseline, it corrodes some plastics. Good luck!
1989 MK1 VW Golf GTi Cabriolet, 'All White Edition' - currently having a new blue roof fitted. Yes it's not white but it requires less Cif to clean
all_whiteGTi said
Rae, to replace the rear window frame this will involve unstapling the roof fabric from the existing one, which will more than likey have been trimmed right back which will make it extremely hard to refit. Have you tried running a thick bead of silicone all around the inside of the window seal, where it overlaps the roof on the outside of the car? This sorted the leak on mine and many others cabbies and could save you alot of work and expense!!
wel i did think about slicone for the time being but the frame is well past it. there is a gap under the window the whole width and about 2" deep. through here you can see into the boot and you can see how rotten the window frame is. the gap gets bigger and bigger every time you open the roof so i have now had to leave the roof be and put a cover over the whole car as im finding huge swimming pools in the boot with the rain.
as for the info on the tensioners- thank you very much
cheers mate
bens_cab said
not unless you fancy blowing the engine apart theres lots of mods to be done before that can be fitted best starting with a g60 engine :wink:
ok that was my original plan. think ill stick with it lol. cheers mate
it appears a lot worse than i even thought. the window basically fell out, then as i started to take the staples out (the ones that hold the roof to the frame) i realised there was loads of movement in the frame. cant believe i never noticed before but the frame is that badly rotten that it has clean snapped appart at the bottom corner
fronts
![](https://vwgolfmk1.org.uk/uploads/pbextract/879551/cabpics009.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/879551/cabpics004.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/879551/cabpics003.jpg)
rears
![](https://vwgolfmk1.org.uk/uploads/pbextract/879551/cabpics005.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/879551/cabpics006.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/879551/cabpics007.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/879551/cabpics008.jpg)
let me know what u say…. new interior?
![han in the usergroup ‘Local’ han in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
rae_cabby said
and now… i just got myself a gti splitter from ebay. one of the deep ones, i think they look so much better
Got a pic or a link mate?
T
sorry tian dont have pics and ive deleted the link, but il take pics when i recieve it and some when on the car
my set is in good condition, one small discrepancy the fronts re velour and the rear is fabric but i never noticed in two years until the ex pointed it out..
pics to follow.
han said
rear ebnch is in for sale section and isnt as bad as it seems. will try and find some of the interior front seats if reequired. altho the fronts are in durham and the bench is in york. can all be togethr if required. where are you based?
pics to follow.
ok wel the only way id be able to give a yes or no answer is to see pics
heres a pic i have to hand not the best
![](https://vwgolfmk1.org.uk/uploads/pbextract/879572/DSC00121.jpg)
but thats the pattern. will get pics sorted for you of fronts.
they come up a treat with some hand shampoo, i was going to strip them back and machine handwash them, but tbh since i got the new interior i'm not bothered about doing anything wit them!!!
